Old 06-17-2022   #1
Erik
Default Best Place to Get Backup Light Switch?
Hey folks.
Whats the best place to get the backup light switch? Rock Auto doesn't list it. Neither did Jerrys.
Thanks
1990 ZR-1 # 996
"All Corvettes are red. The rest are mistakes." - John Heinricy
Erik is offline   Reply With Quote
Old 06-17-2022   #2
HAWAIIZR-1's Avatar
Default Re: Best Place to Get Backup Light Switch?
I don?t know if Zip is the best, but I am happy with mine from them. If you are a veteran ask for their military discount too.
https://www.zip-corvette.com/89-96-6...ht-switch.html
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 06-18-2022   #3
Matt B
Matt B's Avatar
If I remember correctly I got mine from corvette central via their ebay store. Works well and much easier to install thanks to the extended wiring harness.
ZR-1 #638/1991
Matt B is offline   Reply With Quote
Old 06-20-2022   #4
Erik
Zip, Ecklers and Corvette Central are out of stock. All coming in shortly, but today would be much better.
1990 ZR-1 # 996
Old 06-21-2022   #5
dredgeguy
dredgeguy's Avatar
You might want to take out the current switch and clean it. Mine started working again after freeing up the ball and socket.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 06-21-2022   #6
Matt B
Matt B's Avatar
Or try to place a penny into the hole. My old switch worked well but the trigger point has move "into" the switch over the years. So the small engagement rod wouldn't push the ball far enough.
Just make sure you use a shim that's magnetic or can somehow else be removed once you have a replacement.
ZR-1 #638/1991
Old 06-27-2022   #7
Marc Haibeck
Lectric Limited has the switch. PN 10159402.
https://www.lectriclimited.com/
