Old 06-14-2022   #1
Fast36
Default Passenger side airbag sensor
Hi all!
I'm searching for a new (old stock) passenger side airbag sensor for my 1990 ZR1.
Please let me know if you know of any.
Thanks,
Rich Hobatuk aka Fast36
Fast36 is offline   Reply With Quote
Old 06-14-2022   #2
G8nightman
G8nightman's Avatar
Default Re: Passenger side airbag sensor
I have a used one if you cant find a NOS one.
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 06-14-2022   #3
Fast36
How many miles on the car it was removed from? How much do you want for it?
Old 06-14-2022   #4
G8nightman
G8nightman's Avatar
30k miles 100 plus the shipping. Did you try cleaning the rail and resetting code?
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 06-14-2022   #5
Fast36
Yes the rail was cleaned, the code went away, then popped up again. So frustrating.
Old 06-15-2022   #6
NOS on these are a hens teeth item as this was a one year part for the entire MY90 C-4 run. I have only seen used on here for years.
Old 06-15-2022   #7
TX '90 ZR1
TX '90 ZR1's Avatar
Are you sure it is the sensor giving you the trouble? On my '90 it ended up being the connector in the yellow wire inside the cabin. Drivers side connection is behind kick panel just ahead of the speaker and passenger side connection is under carpet on passenger side of the tunnel.
Be sure and have the battery disconnected for a while before you start messing with the wiring!
Kenny
1990 #442
Old 06-16-2022   #8
Fast36
I'll check on that. The code was cleared once but then came back after the sensor was cleaned and reinstalled.
Old 06-26-2022   #9
Fast36
It appears the problem is solved. My technician said he has replaced the sensors in the past, but didn't know about the passenger side connection. He started the car 5 times after he was finished and the airbag light came on, then cleared. Thank god! Thank you for the advice!
