Old 05-30-2022   #1
Default Polyurethane bushings
In another example of the ?while you are there? maintenance of our ZRs, I replaced the rear wheel bearings on my 92. Its been a while and I kept hearing a slight scraping sound coming from the right rear. Put the rear end up and checked for play and yeah left side rocked a bit, left rear was solid. So ordered two Timken bearings from RA. Once I had wheels off, I could see that the rear sway bar end link bushings were shot. So ordered a set of the Poly bushings from Energy Suspension. Fortunately they came in time for me to do the whole job at the same time. Takes longer the older u get! 🤣🤪 Getting the old ones out took a bit but they were clearly the originals.
Long story short, I can definitely feel that the rear suspension is ?crisper?. The increased stiffness is noticeable.
Several years ago I did do Poly bushings all the way around but not the rear sway bar or the rear diff.
Wondering if anyone else has noticed an increased ride stiffness if you have done this upgrade.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 05-31-2022   #2
longhorns05
longhorns05's Avatar
Default Re: Polyurethane bushings
Recently just installed a rear lowering kit w/ poly bushings on my 94. Felt like it tightened things up back there on mine as well. Ironically I think mine needs a right rear wheel bearing too.
93 ZR-1 Red/Red 415ci
Jeal cams/headers, hf cats, B&B
Wilwood brakes, DRM coilovers
94 ZR-1 Red/Blk 368ci
SW headers, hf cats, Corsa
16 GT-R Blk/Blk Stg1 3.8
BL1200X, Shep1k, Motec
1250 whp on pump e85
longhorns05 is offline   Reply With Quote
Old 06-01-2022   #3
Had lunch w Pete P. We discovered that I had installed sway bar upside down. I?ll be correcting that today. 🤣🤣👍
Old 06-01-2022   #4
As Gilda Radner's book title said, "It's Always Something"!--Bob
Old 06-01-2022   #5
Ccmano
Ccmano's Avatar
I tried that with the front sway bar once.... lol. Don't sweat it!
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 06-01-2022   #6
Hans,
Took a bit m. Turns out I had one of the bar links reversed as well. Took it out for a spin today. Ride is stiff but manageable and corners flat.
