Old 04-27-2022   #1
Bcam
Default Tire pressure sensor mount
Hey guys,
It appears that one tire pressure sensor has come loose and is no longer fixed in place properly. I'm not sure how they attach to the wheel, is there a mount or similar that can be replaced on a '90?
~B
Bcam is offline   Reply With Quote
Old 04-28-2022   #2
Kevin
Kevin's Avatar
Default Re: Tire pressure sensor mount
I?m fairly certain that they?re one big band clam. Do yourself a favor and take them off, you don?t need them and it helps with balancing
Old 04-28-2022   #3
Bcam
Thanks for the Reply Kevin, funny you mention balancing, we just spent a a fair amount of time trying to track down the cause of a vibration at high speeds, and this loose sensor was the cause. Unknowingly it kept moving after the tires had been balanced and the vibration would return.
I'd like to keep them though if I can fix it. Can I just get a new band or will I need a whole new sensor?
~B
Old 04-28-2022   #4
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Usually the plastic tabs on the sensors where the band attaches to it is where the failure occurs.
Repairs are not easy or long lasting as the the plastic is hard and brittle.
I favor removing them entirely.
If one lets go at high speed, you will clench tightly.
Save yourself the drama and risk.
Remove them.
Add any current day aftermarket ones that screw on the valve stem and communicate with your phone.
The stock ones were good in the day, but only tell you low pressure, but not which tire like the newer ones do.
Marty
Old 04-28-2022   #5
WVZR-1
~B
Do you know for a fact that the 'system' actually has been operational in the recent past? It certainly can be repaired/replaced but as has been mentioned there's certainly 'better' more sophisticated systems available.
If the car is a driver I'd think the newer technology much more desired.
Old 04-29-2022   #6
mlipmd
With those screw-on-valve-stem sensors you have to balance the wheels after they are installed to get it right.
mlipmd is offline   Reply With Quote
