Old 04-19-2022   #1
Beaver's 90ZR1
Default Throwout Bearing
I need to replace a throwout bearing in my 1990 ZR1 with only 7,000 miles on it. Is there anything I should be looking out for? Anything I should do while I'm in there? Any help or hints I can get will be much appreciated.
Beaver's 90ZR1 is offline   Reply With Quote
Old 04-20-2022   #2
HAWAIIZR-1's Avatar
What led you to the conclusion you need a TOB with only 7K miles on it?
What are you planning on replacing it with. Be careful of the cheap Chinese junk that will have you doing the job again sooner that you wish. If possible get a TOB that has ?INA 04? in the green portion of the bearing. If it is doesn?t look like this one or no marking, the quality is questionable. This one is a Valeo, but there are several manufacturers that used the quality bearing or sold it as their brand.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 04-20-2022   #3
Thomas ZR-1
Thomas ZR-1's Avatar
Default Re: Throwout Bearing
Nearly impossible, the TOB are good for over 100000 mls. People often hear some noise from the bearing area...but in 99% it comes from the pilot bearing in the cranksaft (lost of grease).
[SIGPIC][/SIGPIC]Best thing in life is a ZR-1 ride
Thomas ZR-1 is offline   Reply With Quote
Old 04-20-2022   #4
Beaver's 90ZR1
Thank you both for your quick replies. I'm a 67 year old man that has only dealt with this issue on older vehicles in the past. When I heard the squealing from the clutch being used, it sounded just like a throwout bearing - very loud - never happened before and now I can't get it to repeat itself. I'm not sure what's going on. And, I'll say it again - I MEAN VERY LOUD. Really caught me off guard. Thank you again.
Old 04-20-2022   #5
HAWAIIZR-1's Avatar
You?re welcome. Just drive it. Probably squealing from lack of use. Trust me when I tell you the worst thing for these cars are for them to sit. Having owned three of them and still working for the military for the past 40 years with constant storage and lack of use, I know these cars just need to be driven and not sitting. Any and all problems I?ve had so far is due to lack of use.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 04-20-2022   #6
Vetman
Vetman's Avatar
Mine does the same thing occasionally. It almost sounds like the dual disks making the noise. Just drive it!
1990 Z # 2441
1959 c-1 230 HP 4 speed frost blue/silver 3 owner
2011 cts-v 556 HP, manual 6 speed
1955 chev 2dr ht PP 265 3 speed w/OD
Vetman is offline   Reply With Quote
Old 04-20-2022   #7
viper107
viper107's Avatar
i had a 95 z with 3k miles on it back in 1999, at first start up that bearing would squeel like a pig for 3 seconds and so would the one timing tensioner rattle like a bitch, usually 94 and 5 cars never have that tensioner rattle that i have heard of..
95 admiral blue z(sold)/ / 93 ruby z(sold) 91 steel blue z/95 aqua z haibeck 510, 91 callaway 415 areobody #5
viper107 is offline   Reply With Quote
Old 04-20-2022   #8
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Pilot bushing.
Marty
Old 04-20-2022   #9
Young1
Young1's Avatar
I had the squawk noise on cold startup and getting it out the garage for quite a while when I purchased my Z that had little use for quite some time. It will go away. However if it makes noise every time clutch is depressed even after warmed up maybe you do have TB failure.
Steve Young
Second Owner
SOLD
SOLD
Old 04-22-2022   #10
Beaver's 90ZR1
Again, thank you all so much for your help and quick replies. Drive it we will!!
