Old 03-28-2022   #1
Prez1967
Default Battery Tender for Z?
What are you guys using for battery tenders for your C4?
I bought a "NOCO" battery tender from my local Battery Warehouse but the leads wont fit between the battery and the cars factory positive cable.
For reference:
https://www.amazon.com/NOCO-GC002-Ey...98074315&psc=1
Any solutions? Tips? Tricks?
1994 #353 "Bluey"
Prez1967 is offline   Reply With Quote
Old 03-28-2022   #2
garyhugo
garyhugo's Avatar
Default Re: Battery Tender for Z?
I use Battery Tender.
Gary
90-1572
garyhugo is offline   Reply With Quote
Old 03-28-2022   #3
Prez1967
Is there a way to convert from bolts to studs on the side terminal battery?
1994 #353 "Bluey"
Old 03-28-2022   #4
conesare2seconds
I found a traditional trickle charger led to overcharging issues. Have used this battery minder for several years now with good results. The conditioning / desulfinating feature seems to work as advertised.
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
Old 03-28-2022   #5
Young1
Young1's Avatar
Cut off the eyelets and splice this on and stick it in the cigarette lighter. It what I did with my 750 ma Harley tender from the old days.
Carviya 12V 24V Heavy Duty 16 AWG 15A 20A Male Plug Cigarette Lighter Adapter Power Supply Cord with 1 Meter 3.3 Feet Cable Wire For Car Inverter,Air Pump, Electric Cup https://www.amazon.com/dp/B01HGO2OIS...7XM7F3T2CD80BJ
Steve Young
Second Owner
SOLD
SOLD
Old 03-28-2022   #6
Prez1967
Im actually planning to delete my Cigarette lighter and replace it with a USB outlet.
Something like this: https://www.amazon.com/Lastest%E3%80...s%2C76&sr=8-15
1994 #353 "Bluey"
Old 03-29-2022   #7
HAWAIIZR-1's Avatar
What you?re looking for is this Rockford Fosgate battery terminal extender bolt. Just pull out the stock bolt from the stock cable terminal and you can add connections. They have cheap Chinese imitations but I don?t recommend it. You can use it on both + and -, but I have a quick disconnect on my negative so I have a bolt and washers that does similar.Image1648553994.585641.jpg
I?m installing this Optimate Panel Mount socket in my fender well to just plug in my Battery Tender anytime without popping my hood or fishing/hiding the cable to battery.
OptiMATE CABLE, O-40s, Weatherproof Bulkhead/Panel Mount SAE Power Point https://www.amazon.com/dp/B07TBCNVTS...R39HMPMJTSFZ96
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 03-29-2022   #8
aafc
aafc's Avatar
I have been using the Battery Tender 12v 800ma. It came with both
alligator clips connections and ring connections. the ring ends can be cut off
and wire to the positive side of battery and then to negative side or frame ground. To charge battery connect the ends to the battery charger then plug into your el. outlet and your done.
Check out Battery Tender 12v, 800ma weather resistant Battery Charger.
1990 white/black # 2546
one of a few 4l8OE QE. ZR-1's
aafc is offline   Reply With Quote
Old 03-30-2022   #9
PG ZR-1
PG ZR-1's Avatar
I've been using the different battery tenders from ctek (5.0 to 10.0) on all my vettes
that's the most popular tender in Germany - never any problems
PG ZR-1 is offline   Reply With Quote
Old 04-08-2022   #10
I have been using them (3 now) since 2002. The BATTERY TENDER brand is one of the first "smart chargers" on the market which unlike a trickle charger that will over charge and boil a battery away, the voltage is monitored and the unit folds back into a maintenance routine where it periodically (I'm told) will de-sulfate the battery with a pulse sequence which keeps the formation of the sulfate from obscuring the lead plates - reducing the amperage capacity. I have had batteries last for 14 years and still crank the car(s) like new!
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
