Old 03-22-2022   #1
pattonas
Default Code 36 Fault Issue & Rough Idle
Looking for some guidance. I have a 90 ZR1 1 with 27K miles on it. I jut installed a Billy Boat cat back x-pipe exhaust. Soon after it started idling rough. Service light came on too and I checked for codes and it shows a #36 which I believe is something to do with the ignition/ECM. Car starts just idles poor.
Thanks Scott
pattonas is offline   Reply With Quote
Old 03-22-2022   #2
Default Re: Code 36 Fault Issue & Rough Idle
Is it possible that during the installation the O2 sensors or wires got damaged? Or maybe they are original and were just waiting for an excuse to fail? That could cause some poor running.--Bob
Old 03-23-2022   #3
richarde
It's hard to see a link between fitting a BB cat back exhaust and a code 36. The 1990 Corvette Service Manual has a good diagnostic check for a code 36 on page 6E3-A-56 and 57.
Sent from my iPad using ZR-1 Net Registry
Richard
1990, numbers 1821 and 2391
1821 - owned since Nov 2002, charcoal / Gray, Stainless headers, B&B system, 4.10's
2391 - owned since Jan 2019, Black / Black, have completed restoration. Jeal headers, Corsa system, 4.10's, Aluminum flywheel with Carolina clutch.
richarde is offline   Reply With Quote
Old 03-24-2022   #4
tf95ZR1
tf95ZR1's Avatar
Per Dynomite's Sticky:
Code #36: Direct Ignition System (DIS) Circuit (missing or extra EST signal)
1995 ZR-1 #106 Blk/ Blk
Owned by me since 2000.
93K miles, but not on motor :-)
Mods the way I want it,
Not afraid to drive it!
Old 03-24-2022   #5
viper107
viper107's Avatar
i know one thing,the ecm,s were junk in them years, i would update it to the improved part number , 95 zr-1 ecm in any 92 down z
95 admiral blue z(sold)/ / 93 ruby z(sold) 91 steel blue z/95 aqua z haibeck 510, 91 callaway 415 areobody #5
viper107 is offline   Reply With Quote
Old 03-31-2022   #6
ZR1CK
I had a similar experience with code 36 and 31. 31 being a cam sensor issue. The car started real hard, ran extremely rough, would then all of a sudden run okay and then run rough again and almost stall out, and did a couple of times. I'm not gonna go into details as to what I did to try and chase down the problem, it'll take too long. If you have or can get ahold of the shop manual for that year, follow the diagnostic procedures for that code as mentioned by richarde above. My problem ended up being the ECM. I tried a whole lot of other things before I went to the ECM, hoping it wasn't the issue, but finally decided to send it out to Marc Haibeck to have him check it out. He refurbed it and sent it back and the car now runs great again. By the way, I have a '91 with around 27k miles. Good luck.
ZR1CK is offline   Reply With Quote
Tags
code 36, rough idle
