02-25-2022 | #1 |
Tracking down an oil leak
When I first bought the car it was leaking oil pretty bad. Had the header stud oil leak fixed and it minimized the leak a ton but it is still dripping in one spot. I looked under the car and it is leaking right where the engine meets the transmission. Could it be the rear main? I know Marc says he has never seen a factory installed rear main leak but I am not leaving that possibility out. Let me know what y'all think I'll put a picture of where the oil is landing when it leaks. Thanks.
02-25-2022 | #2 |
Re: Tracking down an oil leak
See this from Marc Haibeck. Finding and Fixing Oil leaks on the LT5.pdf
I would bet on the oil pressure regulator cover leaking and running back to where it is dripping. Check torque on the pan bolts and everything else you can get a wrench on also. Things tend to loosen over time and heat cycles.
Kenny 1990 #442 |
02-25-2022 | #3 |
The rear main seal may not be leaking, however the bolts that fasten a housing the seal resides in can loosen and allow a leak. I did a clutch swap recently and found all 7 bolts were loose and could be rotated with my fingers left or right with no resistance. The area was also wet and it explained why the back of the oil pan was always wet in appearance.
02-27-2022 | #4 |
Went under the car yesterday and I believe my crankshaft position sensor is leaking. The wire going to the connector was wet with oil and when I unplugged it the prongs seemed to have oil on them as well. I will replace that and fingers crossed it will fix it since every other potential leak is a pain to get to lol.
02-27-2022 | #5 |
FYI. The sensor you buy will not be bolt in. It has to be ground and shaped to fit to machined engine block surface. Also apply RTV for extra oil sealing.
02-28-2022 | #6 |
Buy the one from Jerry.. OEM exact replacement
https://www.jerrysgaskets.com/sensor...w-1990-95-1f4/
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - LT4 Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
03-01-2022 | #7 |
Another possibility(?) is the valley drain pipe outlet? The injector housing bolts on my LT5 were quite loose (the first time I had the plenum off). Oil had collected in the area under the starter and was draining via that drain tube to leak beneath the bottom of the bell housing area. (Some BLUE Loktite on the bolts ended that leak (and some others) forever more.)
03-03-2022 | #8 | |
Sent from my SM-G950U using ZR-1 Net Registry mobile app |
