Old 01-06-2022   #1
wfot
wfot's Avatar
Default WTB 93 - 95 oil pan
Does anyone have a 93 - 95 oil pan?
used is preferred.....
Thanks
Putting a 1990 motor in a 1994 chassis and want to get around the different side that the low oil sensor is on.... anyone with insight on this would be appreciated...
wfot is offline   Reply With Quote
Old 01-06-2022   #2
Default Re: WTB 93 - 95 oil pan
Late, 93~95 Oil Pan will not interchange with EARLY 90~92 models.. Bolt pattern is different & oil pickup is very different.
1990 model did not have a low oil level sensor. 91~92 do have low oil level sensor.
Old 01-06-2022   #3
Jagdpanzer
Jagdpanzer's Avatar
The 94-95 pans have several differences including the oil pickup tube, windage tray and baffling. Bolt patterns are also different. Jerry's shows different gaskets.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 01-06-2022   #4
wfot
wfot's Avatar
I am aware that there were several bolt that are different but NOT aware about the pick up tube and windage tray.
it is a 1991 to 1992 as it has a sensor port in the side, thank you Jerry.
what to do then, I have to use the 1991 pan,
Are the wires in the harness long enough to reach the other side?? I am going to bet NO and I really would not want to route wires under/around the pan anyway.
Is there a way to extend the wires properly?
