Old 01-04-2022   #1
Jagdpanzer
Jagdpanzer's Avatar
Default More Whoa Power
Must have been a good boy last year.
Santa dropped off a set of Baer 14" 6 piston disc brakes. Parking brake is incorporated in the rear disc center hats. Same hardware as used on C5 & C6 Vettes. Kit included longer parking brake cables, braided SS flex lines and fittings.
Can't wait for the snow to go away so I can try them out.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 01-04-2022   #2
Jcsws6
Default Re: More Whoa Power
Looks great! What rims are you finishing it off with? I recently installed C6 zo6 brakes and am still on jack stands waiting on the fiskes to arrive....
Jcsws6 is offline   Reply With Quote
Old 01-04-2022   #3
gtcollins@maxnet.co.nz
Cool would like to know the difference have been thinking of this myself
Glen
Sent from my SM-G998B using ZR-1 Net Registry mobile app
Old 01-04-2022   #4
Jagdpanzer
Jagdpanzer's Avatar
18/19 Fikse Profil 10s
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 01-04-2022   #5
tf95ZR1
tf95ZR1's Avatar
So you got them for Christmas and already both
front and rears are installed, wheels/tires back on,
up and running?
I'M IMPRESSED!
Look FANTASTIC!
Congratulations!
PS: More info about the rears, especially the parking
brake setup. Did you have to change the knuckles?
1995 ZR-1 #106 Blk/ Blk
Owned by me since 2000.
93K miles, but not on motor :-)
Mods the way I want it,
Not afraid to drive it!
Old 01-04-2022   #6
wfot
wfot's Avatar
Awesome Phil.
I have the same rotors with 4 piston bears on the front and 12.8 4 piston wilwoods on the rear. I used a wilwood proportioning valve to balance it. really nice upgrade, will pull your eyes out.
The limiting factor became the tires.... need more tire now.
you will love them
wfot is offline   Reply With Quote
Old 01-04-2022   #7
secondchance
As always, impeccable work!
Old 01-05-2022   #8
Jagdpanzer
Jagdpanzer's Avatar
The original caliper mounting plate
is replaced by a Baer provided bearing retainer/parking brake assembly that fits between the suspension knuckle and wheel bearing hub. This assembly is also the mounting point for the brackets which the calipers mount to. The parking brake is a one piece circular shoe expanded by a single mechanical actuator when the parking brake is pulled. The brake drum is incorporated in the disc rotor hat.
Original caliper mounting plate (not used)
Baer bearing retainer/parking brake assembly
Parking brake assembly with disc rotor removed
Parking brake Actuator
Actuator Cable attachment
Parking brake drum
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 01-05-2022   #9
HAWAIIZR-1's Avatar
Nice choice of parts and work as usual Prof Phil!! 🤙🏼
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 01-05-2022   #10
rkreigh
Attachment 17007
Attachment 17008
Attachment 17009Attachment 17010
wow, those look awesome and it's cool retaining the hub emergency brake for less hassle. Bring er out to katies!! looking good.
95 390 LPE ZR1 (505 rwhp)
