Old 11-11-2021   #1
lfalzarano
Default Placement of the air deflector in front of the air filter assembly
I removed the plastic air deflector on my 90 many years ago, that sits in front of the air filter housing and behind the opening in the nose. It?s about 2 feet long and 5-6 inches wide. It has a narrow fold that goes the length and wider fold that goes lengthwise but just about the with of the air filer housing. I have forgotten after all these years.
How is it suppose to be oriented in front of air filter assembly? Any photos or guidance would be appreciated.
Thanks in advance.
Old 11-19-2021   #2
jss06c6
Default Re: Placement of the air deflector in front of the air filter assembly
I've still got mine on my '91. Should be same on '90..20211119_111422.jpg20211119_111407.jpg
Sent from my SM-G950U using ZR-1 Net Registry mobile app
Old 11-20-2021   #3
lfalzarano
Thanks for the photos. There shouldn?t be a difference, but somehow I recall part of it rolled up to the bottom of the air cleaner housing. It your pics it appears to be underneath the bottom of that housing.
When I get it back from the shop, I?ll try it. Clutch master or slave crapped out on me.[emoji35]
