Go Back   ZR-1 Net Registry Forums > Off Topic > Review/Evaluation
Old 10-26-2021   #1
lfalzarano
Default 2023 ZO6 LT6 engine spec
From the assistant chief engineer who states the LT6 DOHC will produce 670HP at 8400 RPMs!
https://youtu.be/_uta6RWwx7s
Old 10-27-2021   #2
Default Re: 2023 ZO6 LT6 engine spec
A great video of the engine and a great explanation of how it works. Maybe I didn't hear it, but I don't think Jeremy asked about how they overcome the inherent increased vibration of a flat plane crank engine, something I would like to hear more about. I would bet that cutaway engine cost at least $100,000 if not much more. --Bob
Old 10-27-2021   #3
tpepmeie
Well, with an 80mm (3.15") stroke, the second order vibration should not be too noticeable. The ford flat plane engine has a 93mm stroke, which is getting up there for such a configuration, so they had to resort to a non-traditional counterweight design (and perhaps firing order?) to mitigate the vibrations.
The LT5 LeMans engine had a 92.4mm flat plane crank, and I'm told it shook pretty bad.
I think 80mm was a great choice by GM for this one. Ferrari F136-type engine in the 430 and 458 were 81mm stroke, and I can personally attest that I never even felt nor cared about any vibrations....
Old 10-27-2021   #4
Todd,
The GM FPC avoids the Ford issue due to using the UDUD configuration whereas the Voodoo changed the firing order and needed to add 50# to the counterweights.
Great explanation of what went wrong for Ford found here.
https://www.corvetteforum.com/forums...post1604219016
Also, I have read that GM will be using their magnetorheological system for the motor mounts.
