![]() Join Date: Aug 2021
I'm installing new fuel injectors on my 1990 ZR1 Corvette and want to know the best way to re-install the injectors. When I removed them, I had to remove the fuel rail first and then pull each injector and it was still one unbelievable pry. Now when installing, should I put the injectors on the fuel rail first and then into the housing or put the injectors into the housing one by one and then installing the fuel rail?
#2 | |
![]() Join Date: Aug 2006
![]() Join Date: Aug 2017
A little lube on the bottom injector O ring and two or three taps front to back on the rail always works.
![]() Join Date: Dec 2003
Do not use a lubricant which contains any silicone, on fuel system gaskets and seals.
Use motor oil or Vaseline which is a mineral based substance. Sent from my iPhone using ZR-1 Net Registry
