Old 07-13-2021   #1
Erik
Default Throttle Position Sensor - Low Voltage?
Hi folks.
My throttle position sensor at idle is reading low. It is reading .37 at idle, vs the factory setting of .53. Is this an adjustment issue, or should I be planning on a new TPS?
1990 ZR-1 # 996
"All Corvettes are red. The rest are mistakes." - John Heinricy
Erik is offline   Reply With Quote
Old 07-13-2021   #2
secondchance
Default Re: Throttle Position Sensor - Low Voltage?
Originally Posted by Erik View Post
Hi folks.
I would try adjusting first.
Old 07-13-2021   #3
Erik
Will do! Thanks
1990 ZR-1 # 996
Old 07-18-2021   #4
According to various sources, the idle air screw is set at the factory and coupled with the TB voltage and IAC module are interactive - especially adjusting the idle air screw. So, it is important to do a diagnostic scan to see that all is well before adjusting anything.
However, TB wear or mods, e.g., porting, headers, or use of reground cams or tuning resulting in altered cam phase changes, etc., may result in a change to the necessary idle speed and consequently adjustment of the Idle air screw and subsequently resetting the TB voltage, etc
If this describes your situation (or perhaps someone else in the same boat), this is (from a tech article I wrote for the HOTB magazine) the procedure that I used to reset the idle air screw on (Ami's) ported and reground cammed 91:
Setting the idle air screw; the procedure:
  1. With motor idling at operating temp, note the TPS voltage and the IAC counts and the RPM requested vs. actual RPM.
  2. Switch ignition OFF. Turn the idle air screw clockwise to reduce IAC counts (to be observed later)
  3. Turn ignition switch ON, but don't start the motor. Instead, set the TPS voltage to 0.54 volts.
  4. Cycle the ignition OFF for 10 seconds and then restart the motor to observe the IAC counts.
NOTE: This (4) step procedure is iterative and depending on how much the idle air screw is tweaked will affect the no. of iterations (to be expected). And, on a stock motor, unless there is significant wear on either the TB bushings or throttle plate seat, etc., one would not expect to have to deviate the factory idle air screw setting. So, one might FIRST want to run a scan to see that everything is in proper working order before attempting to cover up a problem!
Hope this helps (someone)!
Old 07-19-2021   #5
Paul,
Unfortunately this procedure does not isolate the Min Air coming from the throttle body itself. The ECM adds and subtracts IAC steps based on a number of parameters which would still be active if setting IAC in this manner. So the proper procedure is to block off the IAC inlet completely. The easiest way to do that is by extending the IAC fully. I described the process for doing that in another thread which I believe Dynomite may have put in the Stickies.
The objective is to set the throttle opening just a tad below where the motor will idle on its own without any intervention from the ECM. The point of good tuning is to have the motor running as well as possible on its own, keeping ECM intervention at a minimum. The closer to optimal the motor runs, the better it will run. The ECM wasn?t designed to make up for a motor running in sub-optimal condition.
I like my idle IAC to be ~ 10-15steps.
Old 07-20-2021   #6
Paul,
Two means to the same end: After reading your approach, I can see how your approach may be the better way to go - less iterations to get to the same point...is my point!
In defense of my "iterative" procedure, the issue - as result, the car runs terrific and the IAC settled at 6 counts. ALL of the stalling issues and high IAC counts and idle stability (Pete's cams!), stalling after coming to a stop and often a moment after starting a cold engine and high IAC counts were resolved and never returned.
Old 07-20-2021   #7
Absolutely correct Paul. Disabling the IAC helps eliminate the iterative process. And as u note getting the Min Air right really goes a long way in doing away w annoying issues like stalling, high idle etc. If anyone reading this is interested in seeing how the IAC is disabled for Min Air, u can read about the complete process
here.
http://www.zr1.net/forum/showthread.php?t=27764
Old 07-20-2021   #8
Erik
Thanks, gentlemen. This has turned into a better thread then I had hoped. I much appreciated your input.
1990 ZR-1 # 996
Old 07-20-2021   #9
Erik
BTW, this is how my last run looked. Note the low voltage.
After Warming Up:
1990 ZR-1 # 996
Old 07-20-2021   #10
Erik
Cold Start:
1990 ZR-1 # 996
