Old 07-11-2021   #1
blue4:2
Default I am a little confused
I have two ZR-1 -91 but they don`t behave the same, when i turn the power key on. Both cars reacts as they supposed to at about 3000 rpm and runs great ,Car #1 feels quicker and reacts faster and I have noticed that the car
revs according to the tach 2000 rpm at about 60mph at 6th gear and the other car revs about 1500 rpm at the same speed, My idea was that the
final gear was changed earlier in the cars life but after checking that out i was confused, When i turned the wheel one full turn both cars driveshafts turn 3 1/2 turns (the same) Can the tacho give the wrong numbers ?
Only minor mods are made to the higher reving car but the ECM unit is adopted from a 1990 Z (Thank you ccmano) due to a major failure
If you have any ideas please answer
Best regards from Sweden
blue4:2 is offline   Reply With Quote
Old 07-11-2021   #2
TX '90 ZR1
TX '90 ZR1's Avatar
Default Re: I am a little confused
You can use the HVAC controller to check the tach accuracy. Here's a page from the sticky "Solutions". Info is also in your FSM.
http://www.zr1.net/forum/showthread.php?p=144455
Kenny
1990 #442
