![]() Join Date: Jul 2005
Hi everyone.
I've been trying to take care of the little things that help make the car more enjoyable to drive, and of course that includes trying to stop all the rattling and creaking. Oddly enough, my driver side door mirror glass rattles quite a bit. I know how to remove the whole assembly from the door, but is it possible to remove just the mirror glass so I can see behind there and tighten what might be loose? Also, I have the stock radio and the face of the radio rattles. Almost like it's delaminating from itself. Anyone have this happen to them? Visually, there's nothing wrong with it...it just makes noise. Thanks in advance.
Constantine Registry Founding Member #0235 1991 Corvette ZR-1 -- Stock, 94 ZR-1 exhaust system, muffler delete. 1956 Chevrolet Belair -- Pro Street, 531ci Cadillac, 8-71 Blower, 8pt roll bar, built TH-400, 9" rear, 1,100 HP -- Street Car. https://www.youtube.com/watch?v=z8y4cwcvK0s 1968 Mustang "Pegasus" -- Zeeker Chassis, 584ci Dart Block, Brodix Big Brodies, 2-1150 Dominators, FTI 'Glide, 1168 hp, best ET & Trap(holding back) 8.57@159 -- 7.9X -- 1/4 mile car. 1970 Chevelle -- 468ci, TKO600, shaved and smoothed everything. |
![]() Join Date: Oct 2017
Constantine,
The outside rear view mirror can be popped out by putting even pressure on the edges of the glass. When you get the glass out you will see some small screws that hold the adjusting assembly in place. These screws are probably loose or might even have one missing. Put some locktight on the screws and snug them up. Pop the glass back in and you are done. This is a fairly common issue. Sorry, but can't help you with the face of the radio. Might give Dr. Don a call and see what he thinks. ![]()
Kenny 1990 #442 ![]() |
![]() Join Date: Jan 2010
What Kenny says or,
Your mirror rattle is probably due to a broken trunnion or the plastic tabs it snaps into. The trunnion allows side to side and up and down movement of the glass. Someone here may know where to get what ya need to fix it? |
#4 | |
Thank you, all, for the replies. Prior to seeing your responses, I found a helpful video on Youtube with a kid and his Gen 3 Camaro, same mirrors. I pulled it and tightened the outer screw. All done.
I've already spoken with Dr. Don. He's a pretty nice guy, by the way, and we spoke extensively about what I want to do with the radio. He's unsure about the rattle, but thinks it may be loose in the dash. We'll see. I'll pull it and check it out. I'll most likely be sending it out to him for service. Thanks again everyone!
#6 | |
Thank you!
Thank you!
#9 |
![]() Join Date: Jun 2020
My radio buzzes and rattles like crazy too, depending on the road surface. I actually think it's all the buttons getting slightly loose in their mountings. If so I really don't think there's a lot that can be done.
#10 |
![]() Join Date: Sep 2008
Best solution that I have found with 25 + years of ZR-1 ownership to overcome the squeaks and rattles is to absolutely go with the loudest most aggressive exhaust that you can find.
Yes, it will drone. Yes, your neighbors may frown at your 5 AM startup on drive days. You may need a couple of Excedrin. HOWEVER, the smile on your face during each drive will be a lasting treasure. It is now an older Corvette, AKA Born to Rattle. If you want quiet, drive the Lexus. Enjoy the drive, rattles and all! ![]() Marty |
