Old 06-03-2021   #1
Default FS: 1990 ZR-1 Part Out, Lots of Misc Parts
I will start listing as I pull the parts... offers welcome
-Cams- Stock $900 or Performance cams $1600 +shipping
-Coil pack housing $150
-cam sensor heat shield-$20
-throttle body cover with original nuts and torx screw-$70
-Throttle Body - $425
-Cylinder heads - $2,200 plus shipping
-Coolant crossover tube -$300
-MAP Sensor Bracket- $30 OBO
-Targa top rubber covers- 3 $15 per see pics
-MAP sensor cover- $20
-MAP sensor brack torx bolts $15
-MAP sensor cover to bracket torx bolts: $15
-MAP sensor hose-$15(zip tie on grommet)
-Fuel Pressure regulator hose $15 (had zip tie on grommet)
-Fuel rails with regulator- $325
-Bose rear speaker covers- $100 OBO
-OEM ash tray -$20 plus shipping
-Rear bumper without trim $800 plus shipping
Old 06-04-2021   #2
Default Re: 90 ZR-1 Part Out
BUMP for added items
Old 06-04-2021   #3
Old 06-05-2021   #4
Old 06-05-2021   #5
Old 06-05-2021   #6
sleazy rider
will you be parting out the Evaporator housing and inspection cover?
sleazy rider is offline   Reply With Quote
Old 06-05-2021   #7
yes, everything for sale
Old 06-05-2021   #8
sleazy rider
how much?
Old 06-05-2021   #9
Ccmano
Is the diff stock or has it been changed to a different ratio? I'd be interested in a 4.10.
Also what color is the interior? I'm looking for a black driver side door panel and transmission/center console carpet/trim panel. Must be in excellent condition.
H
Old 06-05-2021   #10
Its black Hans it seems to be in pretty good shape will get some pictures
on a side note I scored $3.95 in change under the drivers seat today lol
I have to check the diff I think its stock
