Old 05-20-2021   #1
dmaclennan
dmaclennan's Avatar
Default Clutch replacement (or can I get it rebuilt?)
My shop has determined that the pilot bearing is about to give up. They plan to install a replacement clutch. It doesn't have a dual mass flywheel so they expect the gearbox will be noisier. Hmmm!! I wonder how much noisier.
Any ideas on what my alternatives could be?
Thanks in advance for any help.
1991 with 85,000 miles.
dmaclennan is offline   Reply With Quote
Old 05-20-2021   #2
jw63
jw63's Avatar
Default Re: Clutch replacement (or can I get it rebuilt?)
So you have a DMF now? If still in good shape, and lash is still within spec, you could simply reuse or resurface the flywheel and install a new clutch disc. With 85,000 though and original clutch, you?re probably close to end of life on the flywheel.
My 90 came with a single mass flywheel, and it was very noisy even with heavier weight trans fluid. It?s now very quiet with a DMF installed. I would search long and hard before reinstalling a single mass...but some cars I hear it isn?t that noticeable with.
'90 #413 Red/Red Sold
'90 #1583 Red/Red
jw63 is offline   Reply With Quote
Old 05-20-2021   #3
tccrab
tccrab's Avatar
Jerry's Gaskets has what you need.
https://www.jerrysgaskets.com/search...ywheel&x=0&y=0
'Crabs
Old 05-21-2021   #4
dmaclennan
dmaclennan's Avatar
'Crabs
Thanks for the reference. I've used parts from Jerry's gaskets before. I see you're not too far away from me. Where would you go to get this work done?
Old 05-21-2021   #5
Ccmano
Be careful how you go about this or could end up with a noisy transmission and a clutch assembly that fails in short order because it wasn't designed for the high rpms of an LT5 engine. Most of these "replacements" are LT1 discs and pressure plates. The attached article by Mark Haibeck is a must read to educate yourself on the issues.
http://www.zr1specialist.com/HAT%20W...0in%202019.pdf
Unless your doing performance upgrades try and stay away from a single mass flywheel. The best stock drivability is with the original dual mass. Dual mass flywheels are quite rugged. Unless that car has been abused or raced yours should still be good at 85k miles. They can be resurfaced. Www.ZFDoc.com is the authority. Contact Bill if you need it resurfaced or any trans related advice.
If you do go with a single mass like a Fidanza have them install this shim kit (designed by ZFDoc) to minimize the gear rattle. It easy, I have it in my trans and it made a huge difference.
https://www.carolinaclutch.com/produ...te-c4-shim-kit
While the average Corvette shop should be able to do the work, there a nuances to the LT5 application, as noted in the article above, that they must be aware of.
Keep us posted.
H
Old 05-21-2021   #6
jss06c6
Keep us posted.
H
Definitely get with Bill Boudreau. I've had two client Dual Mass Flywheels as well as Pressure Plates done by Bill (ZFDoc). They are probably better than new!
Stick with the Dual Mass if at all possible..
My $.02 !
Sent from my SM-G950U using ZR-1 Net Registry mobile app
Old 05-22-2021   #7
When Marc did his 510 HP package on my '95 back in 2013, he recommended using the Fidanza lightweight aluminum flywheel to gain 15 HP over a dual mass. I had heard several cars with the lightweight flywheels and they rattled considerably at idle in neutral. Like marbles in a coffee can. Marc says some are quieter. I elected to keep the stock dual mass and despite my "510" package being only about 495, I was very happy to have the quieter dual mass flywheel. especially since it was and is my habit in a stick shift car to always pop my car into neutral at a light or when stuck in heavy traffic. --Bob
Old 05-23-2021   #8
tccrab
tccrab's Avatar
Personally, I'd do it myself.
I've already had my transmission out once before, I wouldn't mind doing it again if I had to.
Since we're talking about the ZF6 and not the LT5, there's lots of competent shops in the area that would be capable of doing the transmission work on your car.
If it were me, I'd find a local shop that specializes on hot rods and restorations.
I would highly advise against even thinking of taking it to a Chevy Dealership or a flat rate shop of any kind.
If money were no object, I'd ship the car down to Bill B (the ZF Doc) at ZR51 Performance in Cave Creek Arizona.
http://zfdoc.com/
Bill is "The Man" when it comes to the ZF6.
'Crabs
Old 05-23-2021   #9
dmaclennan
dmaclennan's Avatar
http://zfdoc.com/
'Crabs
Thanks for the advice. I don't have a facility where I could do it myself so I have to use a shop. I'm talking to Precision Motive in Hayward at this point. I've no intention of going near a Chevy dealer. Your suggestion of Bill B is really good. I'll check out the cost of shipping - might even drive it there
Cheers,
Don
Old 05-23-2021   #10
PhillipsLT5
PhillipsLT5's Avatar
Drive it to Bill if possible, or ship trans to him
