05-05-2021 | #1 |
fuel pump question - which is primary
Going to be swapping out the failing primary pump tomorrow with a buddy using a spare OE pump I have. Which pump is the primary and which is the secondary? I'm sure I can figure it out by the wiring, but I'm guessing you can also tell by the position (one is lower than the other).
Evan
2023 70th C8 HTC, 94 Admiral Blue ZR-1 SOLD - 2012 Carlisle Blue Metallic ZR1 - 800HP SOLD - Steel Blue 91 391cid ZR-1 #391 SOLD - Black 91 ZR-1 |
05-05-2021 | #2 |
Re: fuel pump question - which is primary
The lower one is the primary. The upper one secondary.
05-06-2021 | #3 |
Thanks! That's kind of what I figured.
Evan
05-06-2021 | #4 |
Why not replace both while your taking trouble to pull it all out. Pumps are cheap.
H
05-07-2021 | #5 | |
Oh well, changing the pump is actually pretty easy. And you're correct, they are cheap (didn't realize how cheap). So I guess I'll order a new pair of pumps and go ahead and change both. Anybody try the Autobest HP2251 before? Found it on Rockauto and it's supposed to flow at least 15% more than stock: https://www.rockauto.com/en/moreinfo...sn=908&jsn=908
Evan
05-14-2021 | #6 |
Evan, make sure you also check the harness where it connects to the bulkhead. I've had numerous issues with corrosion there which will shut down the pump(s).
Steve Sent from my SM-G950U using ZR-1 Net Registry mobile app |
