Old 05-04-2007   #1
crazyb1
crazyb1's Avatar
Default rear end movement
I had my rear right wheel bearing/hub assembly replaced last week. Today I noticed that that the same wheel was squeeking again. I also noticed that when I accelerate and decel, the rear end shifts under load, and then shifts back when unloaded. It's very unnerving when at highway speeds you shift and the back end shifts. That's not right. What gives?
'90 ZR-1 Red/Red #1239
SGC P/P Plenum/IH, Headers, B & B, Hurst, K & N
"Red RocketShip!"
crazyb1 is offline   Reply With Quote
Old 05-04-2007   #2
Ccmano
Ccmano's Avatar
Default Re: rear end movement
What you describe was happening on my car before I changed out the rear hubs. So I would suspect there is a problem with the install that was done. Of course deteriorated rubber bushings can cause the same feeling. I would jack one rear wheel off the ground at a time, grab the top and bottom of the tire and see if there is play in the bearing or in the rear suspension bushings. You may have to have someone else watch the bushings to check for movement. Just be safe when jacking the car and use a jack stand to support the car.
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 05-05-2007   #3
I would respectfully add from an apprentice Z owner that you might also check the "C"-beam bolts? If they come loose at the anchor point at the diff housing you could get some pinion rotation...wind-up under load and un-winding under no load....the beam attaches at the front of the diff housing where the pinion gear is.
Just a thought.
Old 05-29-2007   #4
bldavis11
I'm just curious what the outcome of this was. Bearings gone bad?
bldavis11 is offline   Reply With Quote
Old 05-29-2007   #5
Old 05-29-2007   #6
crazyb1
crazyb1's Avatar
I've been out of town for a few weeks. The tire place couldn't figure it out. I just lost my mechanic I've used for the past 9 years so I'm trying to find a reputable shop for the Z. I did drive it a little this past weekend and I noticed that when stopped and I pressed on the brakes, a squeek/type noise comes from the right rear axle area. Same spot as before. Maybe I missed this but could the brakes have something to do with this?
"Red RocketShip!"
Old 05-29-2007   #7
bldavis11
The brakes could certainly cause squeeks. You could have a caliper that's not releasing all of the way among a number of other things. Jack the right rear and spin the tire. Does it bind?
Old 07-30-2007   #8
crazyb1
crazyb1's Avatar
Update and advice: Found out the new hub/bearing assembly was bad. It will be replaced. Also, the mechanic found that the rear arm bushings were cracked and worn. He's trying to replace the whole arm assembly w/bushings but he can't find the whole assemblies from Chevy, and other parts searches. Can/should he just replace all of the rear bushings with one of the available poly kits from a favorite vette catelog or should hereplace all bushings and control arms. That sounds a lot more expensive!
"Red RocketShip!"
Old 07-30-2007   #9
bldavis11
Why do you need new control arms? I'm missing something.
Old 07-30-2007   #10
Ccmano
Ccmano's Avatar
Sounds like it's time for new bushings, the vette catalogs carry them all, poly or standard. Personnaly I'd go with the poly. There's even a variety that has graphite impregnated poly. (less chance of squeeking)
Your mechanic should be able to replace the bushings only.
Hans
