Old 04-25-2021   #1
Matt B
Matt B's Avatar
Default Secondary vacuum pump question
Being unsure if my secondaries work I followed some tips by Mark. And I recognized, that my secondary vacuum pump does NOT run when I turn the ignition on. I measure around 12v at the plug. So power supply is there.
Do these pumps fail? And if so, what are the weak spots?
ZR-1 #638/1991
Matt B is offline   Reply With Quote
Old 04-25-2021   #2
G8nightman
G8nightman's Avatar
Default Re: Secondary vacuum pump question
Yea they do fail specially if they don?t stop running because of a vacuum leak
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 04-25-2021   #3
Matt B
Matt B's Avatar
Okay, good point. I will remove the pump and test the vacuum system!
ZR-1 #638/1991
Old 04-26-2021   #4
Matt B
Matt B's Avatar
Again, thanks for the comment - it made me get up at 6:30 a.m. today and check my pump! In short: it works!
I just pulled the pump and carefully pried it open with a plastic edge. There was no visual damage or sign of overheating. Resistance measurement read around 160 ohm which is a bit high for that motor. So, I winded it manually for a few turns. Car is a low miler, so maybe the motor has some minor corrosion. Resistance dropped to 60 ohm immediately, which is a good sign. Plugged in on and it started dancing!
With the vacuum hose attached it runs for about 3 seconds the first time and then cycles every 12 seconds. Which is not a bad value, right? During the cycles it pumps for way less than a second, probably less than a half.
That's what I call a good start into the day: not having to replace the pump saves me beer money!
ZR-1 #638/1991
Old 04-28-2021   #5
If you need a replacement they can be found for less than $120,same pump used in a KODIAC TOP KICK.
Old 04-29-2021   #6
Matt B
Matt B's Avatar
Thanks, Jeff, good to know. Actually the pumps runs great since I "restarted" it. Curious to see for how long...
ZR-1 #638/1991
