Old 04-03-2021   #1
9T1 Red ZR1
9T1 Red ZR1's Avatar
Default Front crankshaft seal
Hello,
I have a problem with an oil leak on the front of my 1991. I have oil leaking and I thought it was the front seal. I took the belt off, sprayed everything down to clean the oil and started the engine for 1 minute with the belt off. I don't see oil dripping between the torsional damper pulley and the engine like I was expecting. I do have oil leaking from the bolt holding the pulley, and it is coating the inside of the pulley. Is the crankshaft drilled all the way through to the bolt? Is there a seal for the bolt? don't have any oil from the oil switches or oil cooler hoses, it is all on the inside surface of the pulley.
Thanks for your help.
Bill
LT5 Red/Red
9T1 Red ZR1 is offline   Reply With Quote
Old 04-05-2021   #2
Pete
Pete's Avatar
Default Re: Front crankshaft seal
Yes, its drilled thru.
What you can do is take off balancer bolt clean it put some sealent or Loctite 620 on the threads and reinstall.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 04-05-2021   #3
9T1 Red ZR1
Thanks Pete, that is what I will do. I just hope I can get the bolt out!
Bill
LT5 Red/Red
