Go Back   ZR-1 Net Registry Forums > C6 ZR1 > C6 ZR1 Technical Postings > LS9 Engine > LS9 Mechanical
Old 03-26-2021   #1
Horst
Horst's Avatar
Default Where is the fuel pressure sensor?
Hello! I have a small problem with my Corvette, it was running and starting with no issues. Then I put it under a shed in December, and now after two months when I fired it up it worked for about 15 minutes and died. When I try to fire it up again it works for a while and then it goes out straight away again. When I disconnected the battery, the same as I wrote earlier happens: check lights up, and after connecting it back up the scanner pops up as well as the fuel pressure sensor.
Has anyone had this problem before and did they replace the sensor and where is it located?
Horst is offline   Reply With Quote
