![]() Join Date: Apr 2017
I saw this wheel well venting idea on another ZR-1.
I really like the idea. Has anyone any information on this? Dimensions? I hope that there is an article or write up on this idea. Wheel Well Small.jpg
[SIGPIC][/SIGPIC] 91-#1935 Black/black & gray, Haibeck 500 Cams by Pete |
![]() Join Date: Dec 2007
90 Chevy ZR1 LPE #2315 'SOLD' 90 Chevy ZR1 LPE #2774 'SOLD' 91 Chevy ZR1 Callaway aerobody 91 Chevy ZR1 #1512 91 Chevy ZR1 #951 95 Chevy ZR1 #338 'SOLD' 91 BMW 850i 94 BMW 850csi 95 BMW 850csi 94 Lotus Esprit S4 07 Benz CLS550 06 BMW M5 "SOLD" |
![]() Join Date: Feb 2011
It would let a lot of moisture in the engine compartment when driving in the rain. I don?t believe it would lower the temperature in the engine compartment.
![]() Join Date: Feb 2010
I have used this system from A/O Engineering ( no longer in business).
Three fans about 5in flows 50 cu ft of air each fan. With 3 fans on each side I can remove about 150 cu in of air out of the engine bay( each side for a total of 300 cu in) I also added a switch so i can turn the fans when ever i want. Works great when stopped as I can turn the fans on before engine reaches 185 deg to cool motor. |
![]() Join Date: Jan 2010
Fans worked for Jim Hall on the Chaparral 2J
![]() Join Date: Feb 2012
#7 | |
![]() Join Date: Jul 2020
There are several fans like these available on Amazon various diameter and CFM. IP67 rated should do the trick. |
#8 | |
![]() Join Date: Aug 2006
#9 |
Already have that. Not enough. Although I'm suspicious of possibly air in the system and needing to bleed it or top off.
#10 |
![]() Join Date: Jan 2004
I have installed these air vents on all of my C4s. You just make a template of the design you like and epoxy the screen type of your choice. Water does not enter your engine bay while driving in the rain due to air pressure under the hood.
I did this to my ZR-1 back around 2006 with no issues. Last year I did my 92 Z07 and GS. Tools needed are 1. Dremil tool for cutting plastic or like item, 2. Clear epoxy for plastic, 3. Screen type of your liking. You can feel the heat come out of you wheel wells with hood closed.
Tony Davila (Projects) Water Meth: http://www.zr1.net/forum/showthread.php?t=19422 Exhaust cut outs: http://www.zr1.net/forum/showthread.php?t=22689 Auxiliary 12V install: http://www.zr1.net/forum/showthread.php?t=22878 Auxiliary pusher fan install: http://www.zr1.net/forum/showthread.php?t=22859 Oil Catch can Project: http://www.zr1.net/forum/showthread.php?t=20320 Last edited by Tony Davila; 03-17-2021 at 05:27 PM. |
