Hello all,
I think it?s about time to pull my rack and pinion and send out to Turn One for a rebuild. At lower speeds it doesn?t feel too bad, but noticeable slack until it feels like the wheels are responding. At anything above interstate speeds, the term numb even seems an understatement, more like nerve wracking. While I have the rack out, I?ll rebuild the power steering pump and replace what I can with the hoses. The car is at 90,000 miles. I?m curious as to anyone?s substitute hoses or part numbers for using in place of the factory hoses that may not be available. |
#2 | |
![]() Join Date: Aug 2006
84 after about 80,000 miles started to exhibit what is called morning sickness. This is a sysmtom, when the car is cold, experiencing momentary lack of power assist. This sysmtom, I believe, comes from deterioration of internal O ring and require rebuild. With my 94, at around 130,000 miles, started to notice sloppiness especially between left and right - at center. Long story short, I too had the rack rebuilt at Turn One (best outfit for C4 rack rebuild best I can tell) and during the install, noticed lower control arm bushings at the rear had worn out to a point where rear of lower control arm was moving as much as 1/8?. I replaced both rear bushings (left and right). This improved the situation but did not cure the vague fell completely. Removing the steering rod, I could tell that there was tiny sloppiness at the rag joint. This tiny slop, at the steering wheel was getting amplified to as much as 1/4?. While removing and replacing the rack, go through those components I described. As far as hoses, they are ZR-1 specific but you should be able to reuse without replacing. |
![]() Join Date: Jan 2004
they are a bit hard to get. But I found a tip. if the ends are bad, look up a trucker buddy. They get hydraulic hoses made up custom all the time and it's affordable. I'd like to use some nice aftermarket braided hose that would look cool
Thank you for the recommendations. Had a fellow forum member hook me up with a new replacement pressure side hose. The rack is out and I knew it would be rough in the area behind the power steering pump but more than I was expecting. I tried to cheat removing the PS pump and reservoir by sliding it down into the empty space the rack had occupied. No dice.
Have to drain the coolant and remove part of the coolant system per the FSM. Attaching some pics to see what could be causing the leak. The lower end cam plug was a little wet. As for the rest deep down...guess I won?t know until I crawl under and start cleaning. Turn One has a turnaround time of about 3 or 4 weeks so I guess that gives me time to clean and pinpoint the leak. Last edited by 1991 Corvette ZR-1; 02-23-2024 at 10:34 PM. |
I cleaned things up a little for a start. There?s actually an LT5 under that stuff. The bottom of the compressor is caked. Part of me wonders if there was a leak from the compressor but that?s too convenient. I?m going to say it?s most likely the front pan bolts are loose and seeped oil which has covered most of the front of the block over the years.
![]() Join Date: May 2010
It looks like you are doing a nice job there Jamall. It does not look like a current leak so curious to know what you find. Best wishes with the repair.
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
#7 | |
I remember the PVC box gasket I replaced had the same blue pinstripe, so I am assuming this is a piece of an original factory gasket. I?m aware of the oil pan bolts loosening but have never heard of the front cover bolts doing the same. I?ll check torque of what cover bolts I can from under the car now that the rack is out. Last edited by 1991 Corvette ZR-1; 02-23-2024 at 10:34 PM. |
Water Pump gasket 👍
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS |
#9 | |
You are welcome. I agree with Dynomite and he has Bingo. One thing always seems to lead to another with our cars. Sent from my iPhone using ZR-1 Net Registry
#10 |
Thanks, guys. That?s a relief and it makes sense because the water pump did look a little brighter than the surrounding aluminum. Rack is all crated up and shipping out tomorrow. It?s probably overkill but I?d rather pay extra and have piece of mind the hard lines are not in danger.
