Old 02-08-2021   #1
Erik
Default TSB for Additional Under Plenum Drain?
I was given a link once to a TSB that was apparently for additional drainage under the plenum. However, the link was dead.
Any idea where I could find it?
1990 ZR-1 # 996
"All Corvettes are red. The rest are mistakes." - John Heinricy
Erik is offline   Reply With Quote
Old 02-08-2021   #2
Default Re: TSB for Additional Under Plenum Drain?
3/8" diameter hole in the valley
GM Service Bulletin #92-307-6
Old 02-08-2021   #3
Corvette95
Corvette95's Avatar
You know a trick I have done a few time although my plenum never really gets dirty, it run a long hard vacuum line up the valley drain and spray electrical clean up the hose, can also use brake clean but thats second choice due to the DIS.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 02-08-2021   #4
Erik
Good to know. Thanks!
1990 ZR-1 # 996
Old 02-09-2021   #5
Young1
Young1's Avatar
I use my rubber tip air blower on the pipe every time I do an oil change even though a dealer long ago drilled the hole.
Steve Young
Second Owner
SOLD
SOLD
Old 02-13-2021   #6
Corvette95
Corvette95's Avatar
Yep, air works too. I like to do the cleaner to keep oil from building up but it?s risky but been lucky for years with it !
Old 02-15-2021   #7
Blue Loctite when torquing down the IH and the air breather dome does wonders too, far as preventing oil from leaking down into the valley in the first place. (Just sayin!)
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 02-15-2021   #8
Corvette95
Corvette95's Avatar
I am glad YOU posted that Paul. I was going to but didn't want to take the heat for NO SEALANT ON PLENUM OR IH BOLTS REPLIES! After three additional torque sequences after install, yeah, next time, blue loc-tite for sure! Although dry as a bone after the third re--torque!
Old 04-05-2022   #9
Gsgnz
Is it ill advised to drill this hole from the flywheel side?
Gsgnz is offline   Reply With Quote
Old 04-07-2022   #10
I have read where some have suggested such a hole drilled there. But, I think not having a tube to channel the oil clear of the FW might be an issue. OK, I've watched this FORUM for over 15 years and have yet to see any followup from anyone who did drill an aux drain hole. But, preventing oil leakage in the fist place and/or periodically cleaning out the drain pipe (as suggested) appears to be a better solution(?) Just sayin!
90 #1202
Sans secondaries
