Old 12-28-2020   #1
Corvette95
Corvette95's Avatar
Default Verification of this vacuum line (pic inside) (1990)
Double checking, the top vacuum line mounted to the power steering pump went to the now deleted exhaust air pump..correct? I can cap this top line (it has vacuum line attached now in this photo - was going to remove and cap) also replacing the unneeded "T" on the drivers wheel well with a straight connector since the addition of the headers and removing the AIR valve.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 12-30-2020   #2
Young1
Young1's Avatar
Default Re: Verification of this vacuum line (pic inside) (1990)
I went out to look ar my 91. It only has one vacuum line at that location. Someone with 90 needs to respond please. Hey Joel in Tampa that has an NCRS 90 help out a brother.
Steve Young
Second Owner
SOLD
SOLD
Old 12-31-2020   #3
Pete
Pete's Avatar
Might be needed for cruise control.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 01-03-2021   #4
Corvette95
Corvette95's Avatar
Humm, I need to break out the FSM, I thought this would be an easy question. I thought I unplugged it as part of the header install
Old 01-03-2021   #5
secondchance
My 94, this vacuum line continues to a ?T? fitting and I think one line goes to vacuum tank and the other to cruise control - I think.
Old 01-03-2021   #6
Corvette95
Corvette95's Avatar
Thanks, still working on transmission and exhaust and haven?t really researched it much yet.I know there was a T on the a.I.r pump that I removed but that I just needed to install a straight vacuum adapter. I?m sure it will be evident when I investigate and look at FSM. Again, just thought it would be an easy answer. Thanks
Old 01-03-2021   #7
I will try to check my 1990, but as I recall, I think I am still using that line fto the front of the car. I think that is for the Purge solenoid for the Charcoal canister..
Old 01-06-2021   #8
Corvette95
Corvette95's Avatar
Well, its parts of the cruise, I believe it ran from the A.I.R module to the power steering line clip as shown and then to another adapter that went to the A.I.R module. Thats how I have it hooked up now, probably needs a longer piece of hose.
