Old 12-09-2020   #1
Erik
Default I guess it wouldn't be a ZR-1 without an oil leak.
Parked inside since the weekend, and I took a look at her today. Found a nice puddle under the front of the engine. It already has Jerrys oil cooler lines, so I doubt it is that. Was pretty dark too, so I'll have to check again in the AM.
Only thing I can imagine is engine oil, or PS fluid?
1990 ZR-1 # 996
"All Corvettes are red. The rest are mistakes." - John Heinricy
Erik is offline   Reply With Quote
Old 12-09-2020   #2
Default Re: I guess it wouldn't be a ZR-1 without an oil leak.
Check oil pump access cover and cam sensor seal. I had both happening at the same time.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 12-09-2020   #3
Erik
Will do.
Are they easily repairable, or is it a special part required, otherwise known as another Jerrys order?
1990 ZR-1 # 996
Old 12-09-2020   #4
Ccmano
Ccmano's Avatar
Passenger side?
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 12-09-2020   #5
Erik
Originally Posted by Ccmano View Post
Passenger side?
H
Could be.
I'll know more tomorrow.
What's on the passenger side?
1990 ZR-1 # 996
Old 12-09-2020   #6
secondchance
Originally Posted by Erik View Post
Could be.
On the oil filter housing facing forward low an hidden - oil temp sensor
On top of oil filter housing - oil pressure sensor
Right side of filter housing facing down - low oil pressure warning sensor
Under and behind low oil pressure sensor - cam chain tensioner port
Above oil pan - crankshaft sensor
Under the crankshaft sensor, on the oil pan - low oil level sensor
Of course, oil pan gasket can be a source of oil leak also.
Oil leak can be any of above or combination of above locations.
Old 12-09-2020   #7
Ccmano
Ccmano's Avatar
Yup, lots to leak...
H
Old 12-10-2020   #8
Erik
Iirc, we did all the sensors. So I'm guessing that narrows it down some. Plus, previous owner had the oil pan dealt with. So that should make the options just a few.....
We will see next week when she is in the air.
1990 ZR-1 # 996
Old 12-10-2020   #9
You can immediately eliminate all the ones that are easy to get to.
Old 12-11-2020   #10
Erik
Thanks for that note of encouragement.
1990 ZR-1 # 996
