12-01-2020 | #1 |
Oem windshield
Is this a oem windshield for 1992?
I don't know if the pic is visible but it says Sunshade Solargreen PPG Duplate Laminated Safety float AS1 41 71 Dot 18 M405 Dw1112 IMG_6754.jpg Sent from my SM-G988W using ZR-1 Net Registry mobile app Last edited by jaykran; 12-01-2020 at 05:39 PM. |
12-01-2020 | #2 |
Re: Oem windshield
What year is your Z?
If 90 - 93 (I?m guessing) there should be roughly 3? high and 4? wide clear area slightly overlapping defroster grille in the center of the dash. If later years, similar clear area of same height but reduced width around 3?. If you don?t see clear ?radar detector port?, it?s non-ZR1, standard C4 windshield. |
12-01-2020 | #3 |
Re: Oem windshield
BTW - if you see question marks, these are either double apostrohies or single apostrophe.
12-01-2020 | #4 |
Re: Oem windshield
