Old 11-27-2020   #1
Erik
Default Is It Bad If This Is Rattling Around Inside?
When I took my car to the new tech, he removed the ECM for some troubleshooting. He was surprised when he had it out that something inside was rattling. This is what he found:
File Type: jpg 8124CE2E-92FD-427D-9317-7CB22968FBCD.jpg (77.5 KB, 73 views)
1990 ZR-1 # 996
"All Corvettes are red. The rest are mistakes." - John Heinricy
Erik is offline   Reply With Quote
Old 11-27-2020   #2
Default Re: Is It Bad If This Is Rattling Around Inside?
yes.. car might not run right..
Old 11-27-2020   #3
Erik
How'd you figure that?
1990 ZR-1 # 996
Old 11-27-2020   #4
Well I am assuming you are joking.. but, Mine came loose and caused a mness of issues..
Old 11-27-2020   #5
Erik
Indeed I was. And yes, mine did the same. I had the pleasure for paying for this poor quality repair.
1990 ZR-1 # 996
Old 11-27-2020   #6
Pete
Pete's Avatar
If you want i can solder the chip to your MEM-CAL and will never have that issue again.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 11-28-2020   #7
Erik
Pete
Thanks Pete.
That?s good to know.
Let me see how this goes.
Erik
1990 ZR-1 # 996
Old 11-28-2020   #8
Pete
Pete's Avatar
Thanks Pete.
Erik
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 11-28-2020   #9
jss06c6
Have seen one using the G1 chip adapter come loose. It was the MEMCAL chip assembly detaching from the G1 adapter because the G1 wasn't fully seated. The G1 should "clip" in just like the MEMCAL unit does.
Agree with Pete that soldering is a permanent solution, but the G1 should not cause issues if installed correctly..
Securing the "piggyback" assembly if it came loose is a 5 minute repair... you can add a dab of silicone (for electronics) to help if the G1 to MEMCAL is not tight.37751.jpg
Sent from my SM-G950U using ZR-1 Net Registry mobile app
Old 11-28-2020   #10
Erik
Securing the "piggyback" assembly if it came loose is a 5 minute repair... you can add a dab of silicone (for electronics) to help if the G1 to MEMCAL is not tight.Attachment 13587
The repair was indeed easy. It was the troubleshooting done ineptly by the first mechanic that was the issue.
1990 ZR-1 # 996
