![]() Join Date: Nov 2016
I was thinking of adding a battery disconnect switch, rather then just constantly removing and replacing the negative battery wire. Any good recommendations for one?
1990 ZR-1 # 996 "All Corvettes are red. The rest are mistakes." - John Heinricy |
![]() ![]() Join Date: May 2010
I like this one from Amazon and had it for about 7 years with no issues (made in the USA too) I agree it sucks to keep having to remove the terminal. Side Post Battery Master Disconnect Switch https://www.amazon.com/dp/B001N72FES...ing=UTF8&psc=1 Sent from my iPhone using ZR-1 Net Registry
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
#4 | |
This Moroso seems the be the same brand (GAMA) as the one I posted. Sent from my iPhone using ZR-1 Net Registry
#5 | |
![]() Join Date: Jul 2007
Why are you always connecting and disconnecting the battery? I can understand for longer term storage, but anything less why not a battery tender? I have been using a tender for 25 years. Batteries typically last me 5-6 years as expected
I will likely get a tender too. Just new to the car, and not too sure how well everything electrical is operating yet.
#8 | |
![]() ![]() Join Date: Nov 2007
![]() Erik: A quick disconnect switch, safety not withstanding, is practical if the car is in storage where AC power is not available, especially if the storage area is in sub-freezing temperatures (colder temps slows chemical "sulfate" buildup particularly when not being regularly charged).
#9 | |
#10 | |
