Old 11-22-2020   #1
Erik
Default Most European Sounding Exhaust
As much as I love my ZR-1, it does bug me that my 2019 Mustang Bullitt sounds a lot better. I'd love to add an exhaust to my ZR-1, but what I don't want is something that makes it sound like a typically rumbly Yankee V8. I'd prefer something that highlights the Lotus/European 4 cam sound of the LT5. Of all the exhausts available, which would be closest to what Im describing?
1990 ZR-1 # 996
"All Corvettes are red. The rest are mistakes." - John Heinricy
Erik is offline   Reply With Quote
Old 11-23-2020   #2
Mystic ZR-1
Mystic ZR-1's Avatar
Default Re: Most European Sounding Exhaust
Here ya go Erik!
Right up thru the hood!!!😀
File Type: jpeg 114EA9AA-C572-414A-A798-1E1F1431A8FA.jpeg (21.5 KB, 121 views)
Old 11-23-2020   #3
Erik
Here ya go Erik!
Exactly what I was looking for. How did you know? :P
1990 ZR-1 # 996
Old 11-23-2020   #4
EvanZR1
EvanZR1's Avatar
Corsa. Has a higher, more exotic tone. Here's a video of mine on a back road drive. This was from inside the car, but with a hatch vent in place so you can really hear it. Granted mines a 391cid with stage 2 cams, so it's a little rowdier than a stock LT5:
https://www.youtube.com/watch?v=20ZOyqaoweQ&t
EvanZR1 is offline   Reply With Quote
Old 11-23-2020   #5
I tested many exhausts in the early years ('90s, early 2000s) and concluded at the time that Corsa had a more "European" sound, which I would describe as a little higher pitched that the typical Mustang type rumble. The sound difference from the Mustang is partly due to different firing orders I think. The difference between aftermarket brands on the ZR-1 was more due to exhaust pipe diameter (bigger was deeper and louder) and general exhaust and muffler design. The Corsa was the best aftermarket system at reducing drone or resonance. I used Corsa for years on both Z's until I finally went to the stock system with cutouts on the '95. One thing I did not like about the early Corsa was that I could perceive individual firing pulses more than I liked which was due mostly to the almost complete segregation of the left and right sides (only a tiny "H" pipe at the front of the center resonator connected the two sides). I modified my Corsa resonators to allow much more sound wave crossover from each side to the other and it improved and smoothed the sounds for me. Nowadays X pipes accomplish this to a certain degree.--Bob
Old 11-23-2020   #6
Erik
That sounds magnificent. Thank you!
1990 ZR-1 # 996
Old 11-23-2020   #7
Erik
The Bullitt was actually designed to sound like a 68 with a 390. It does sound fantastic, especially starting in the garage. It also has 4 different modes, from polite to very rowdy, and is one of the best parts of the driving experience. The Coyote is NOT an LT5 however, regardless of the fact that it has 100 more horsepower. Just no where near as special.
1990 ZR-1 # 996
Old 11-23-2020   #8
Mystic ZR-1
Years ago I had Monza mufflers on my 84
Black crinkle finish, two slim glasspacks each side,
chrome slash tips, nice mellow sound. Monza made after market
exhausts mostly
for European cars. Dunno why they made them for a Vette?
Don't think they're around any more?
Old 11-23-2020   #9
conesare2seconds
^^^ Used to see Monza offered in Mid America, Eckler?s, Corvette Central, etc.
Old 11-24-2020   #10
I agree w/ the Mustang exhaust note being "mo bettah" than the old (pre-LS) Chevy V8s, including the LT5.
However, the firing order (the actual cylinder position firing order, shall we say) of the LS motors is now the same as the FORD 5.0, 351s (both), 400, and the modular V8s
Attached is a chart of "Common Firing Orders". If you trace the firing orders of the FORD V8s and the newer GM LSx V8s, beginning at the #1 cylinder for the LS and the #5 cylinder for the FORD engine and proceed to trace the routes, you'll notice the cylinder position firing orders are identical.
The difference in these examples (I'm told) is in the firing order dictated by the cam(s). One could (I suppose) start with billet cams and grind the LT5 cams to emulate LS and FORD firing orders.
Start with the lower right cylinder in the LS and Ford motors and trace the position of the cylinder firing order and see whacha discover!
