Go Back   ZR-1 Net Registry Forums > C6 ZR1 > Cleaning and Waxing
Old 11-22-2020   #1
GrayZ
Default waxer
Some haters call me a waxer, others, call me much worse.
I have used a lot of different products.
I will be posting, some, results, products...i use...etc...
p.s. shut it, Craig
GrayZ is offline   Reply With Quote
Old 11-22-2020   #2
GrayZ
Default Re: waxer
here is my car after a quick Missouri rain shower, i used a micro fiber towell to wipe it off, and it shines like a baby, I recently used the Adams Graphene detail spray, this stuff is magic.
File Type: jpg 121828341_10217757616480228_154096752590237072_o.jpg (259.5 KB, 35 views)
Old 12-02-2020   #3
EvanZR1
EvanZR1's Avatar
Default Re: waxer
I have found that a good clear bra and good (professional) ceramic coating on top of it makes things much, much easier. To the point where typically I just use a pressure washer to blow the dust off, then use a high power leaf blower to blow the water off and car comes out looking perfect.
Evan
2023 70th C8 HTC, 94 Admiral Blue ZR-1
SOLD - 2012 Carlisle Blue Metallic ZR1 - 800HP
SOLD - Steel Blue 91 391cid ZR-1 #391
SOLD - Black 91 ZR-1
EvanZR1 is offline   Reply With Quote
Old 12-25-2020   #4
Corvette95
Corvette95's Avatar
Default Re: waxer
I found this by accident https://www.3m.com/3M/en_US/company-...3193940&rt=rud
works super well as is but it will also take excess wax and polish off removing swirls. I use it when I remove the wax with a dishwashing liquid prior to claybar. It really prepared the surface for new polish or wax. If you apply if straight back and forth or up and down it will remove spider webbing if you apply the wax and or polish striaght up and down or back and forth. I do not believe in circular application or washing. This will also clean all the little trim you get wax or polish on and leave zero residue.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
