Old 11-13-2020   #1
spork2367
Default secondary issue
Pulled my intake for a starter issue and was doing a quick vacuum check and found the passenger side secondaries sticking. Upon further investigation I found this...The bent butterflies don't appear to have caused the sticking issue, as it was still sticking after their removal. What else would cause this?
Old 11-13-2020   #2
Ccmano
Default Re: secondary issue
The vacuum actuators certainly don't have enough force for something like that. I wonder if somewhere along the line there was a backfire that caused it. Are they all like that?
H
Old 11-14-2020   #3
H
Backfire...was my guess too.
Old 11-14-2020   #4
Bent shafts can cause sticking. Did you remove them too?
Old 11-14-2020   #5
Ccmano
Time to just omit the secondaries altogether. I have a set of butterflies if you need them.
H
Old 11-16-2020   #6
spork2367
That was my only guess, but I find it hard to believe. This was just on the back two cylinders on the passenger side.
After I pulled these two butterflies, everything freed up. I'm going to straighten them and refit them.
Old 11-17-2020   #7
Jagdpanzer
Jagdpanzer's Avatar
A real mystery. With the adjacent intake valve being open or closed more or less at the same time hard to imagine that much force being generated that would bend a secondary butterfly like that. Has anyone else every experienced this?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 11-17-2020   #8
Jagdpanzer
Jagdpanzer's Avatar
I have a few new take out butterflies for free if you need them.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 11-18-2020   #9
spork2367
I appreciate that. Let me see how flat I can get these first.
Old 11-20-2020   #10
H
That'd be MY vote too!!
