Old 10-19-2020   #1
carman49
Default WTB: SIR Sensor
I need the left SIR sensor that goes on the frame under the battery tray. I also believe that I can make a right one work.
90 ZR1 vin 414
carman49 is offline   Reply With Quote
Old 10-19-2020   #2
Ccmano
Default Re: WTB: SIR Sensor
At the risk of stating the obvious, are you sure it needs to be replaced? 99% of the time the it's simply the sensor ground to the chassis that needs to be restored as per... https://www.corvetteforum.com/articl...990-corvettes/
The 1990 sensor can be tricky to find as it's a one year only piece, although valid for the base and the ZR-1 corvettes that year.
Good luck...
H
Old 11-25-2020   #3
ursoj89
not sure if you are still looking but I have a brand new one that I purchased with my car. Make an offer.
ursoj89 is offline   Reply With Quote
Old 12-07-2020   #4
carman49
I sent you a PM
