09-23-2020 | #1 |
95 z tire pressure sensors
what are you guys doing when you go aftermarket wheels about the tpms sensors? if removeing them what you doing about the light?
95 admiral blue z(sold)/ / 93 ruby z(sold) 91 steel blue z/95 aqua z haibeck 510, 91 callaway 415 areobody #5 |
09-23-2020 | #2 |
Re: 95 z tire pressure sensors
1995 zr-1 car
09-23-2020 | #3 |
09-23-2020 | #4 |
thanks i thought so
09-23-2020 | #5 |
All that you can do is to remove the bulb for service LTPWS.
When I was young we had to rely on our own wits to recognize when a tire went flat. We also had these things called tire pressure gauges that you manually placed on each valve stem to check your pressures often and adjust accordingly. Worked then. Works now. Marty |
09-23-2020 | #6 |
yeppers!!!
09-23-2020 | #7 | |
We have maybe lost that sense of "feel" that used to be important for driving... |
