I need to replace the clutch master cylinder on a car that is 70 miles away. Can anyone tell me what size wrench in need for the hydraulic line fitting that attaches to the master? TIA
#2 | |
![]() Join Date: Nov 2007
That said, wouldn't it make more sense to just take a metric set of wrenches and sockets w/ you? (Sounds like you're traveling pretty light - to take the exact (one and only) wrench(es) w/ you! You also might want to have a pair of needle nose pliers and a hook set in the bag too. |
Thanks Paul, just wanted to make sure I have the right size flare nut wrench with me. I dont use open end wrenches on flare nuts when I can can avoid it.
![]() Join Date: Sep 2016
It?s that clip up under the dash that makes my back hurt to type about it.
![]() Join Date: Jan 2010
Spend 10 minutes to take the driver's seat out 1st.
Your back and typing finger will thank you... |
![]() Join Date: Feb 2012
