08-02-2020 | #1 |
ZR-1 Parts
A list of used items as follows. Some are ZR-1 specific and some are not. Most parts are from a 91 ZR-1 #1437 with 28,028 miles on it
Electronic AC / Heater control $150 OEM water pump (needs rebuild) $100 Fuel lines under hood $40 92 to 95 ZR-1 Full Power Bypass switch (new) $20 Headlight relay switch $50 AC Controller module $125 Body Control module ( shows milage 28,028 ) $175 ZR-1 prom $90 Black 1990 drivers side gill panel $25 Black fuel door lid and panel $40 Air duct to throttle body $40 Head bolts (20) $200 Cam chain guides L & R $80 Cam chains $25 each Cam chain idler sprocket $50 Dual mass Flywheel $300 I will post up more parts later. Pictures by phone work best for me if you want to see something. Thanks
91 ZR-1 #661 Watsons, 3" exhaust, Borlas... Hurst, 4.11s, Samco, RD radiator, gel coated motor... turquise / black |
08-02-2020 | #2 |
Re: ZR-1 Parts
I might be interested in the full panel, but would like to see what else you have
08-03-2020 | #3 |
Re: ZR-1 Parts
What year prom?
08-03-2020 | #4 |
Re: ZR-1 Parts
Do you have the inlet coolant line (heater hoses from heater core to thermostat housing) . Radio bezel with power switch and key? Lumbar seat pumps? Plenum metal PCV pipes and metal vent tubes to injector housings? Steering column turn signal switch (this looks similar to the ignition switch - it't not the turn arm, it the plastic housing and wiring the arm goes in to) thanks.
08-03-2020 | #5 |
Re: ZR-1 Parts
PM sent about dual mass flywheel
'90 #413 Red/Red Sold '90 #1583 Red/Red |
08-03-2020 | #6 |
Re: ZR-1 Parts
What is the best price you can do for all 3 cam chains shipped to NJ 08088?
thanks John |
08-04-2020 | #7 |
Re: ZR-1 Parts
Pretty certain its the stock one that goes in a 91.
08-04-2020 | #8 |
Re: ZR-1 Parts
In other words it has the knock sensor circuit on board.
If yes, pm me $. Edit: Never mind I see it. I will pm u.
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 08-04-2020 at 12:49 PM. |
08-11-2020 | #9 |
Re: ZR-1 Parts
Do you have the feeds and return lines that connect to the fuel rails?
