Old 08-01-2020   #1
Default Air filter comparison...OMG!
Jeeze Loueeze!
I believe I'll be making a change in my air filter selection after seeing this!
DAYAM!!!!
Old 08-01-2020   #2
Ccmano
Default Re: Air filter comparison...OMG!
I like the way he conducted the tests. With the little bit I drive the Z the K&N is staying. For a daily driver, different story.
H
Old 08-01-2020   #3
Tripler
Tripler's Avatar
Project Farm does amazing test of tons of products
Been subscribed for 2 years now lol . How did I miss this one tho .
Sent from my SM-A205W using Tapatalk
Tripler is offline   Reply With Quote
Old 08-01-2020   #4
HAWAIIZR-1's Avatar
Thanks P! This was enlightening! [emoji33]
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 08-01-2020   #5
efnfast
Huh, maybe i don't like my K&N so much anymore. Do they come pre oiled, did he neglect to oil it?
Old 08-01-2020   #6
Marc to.d me sometime ago he uses the AC filter. Frankly, if I?m going to the drags, I?m pulling the filter altogether.
Old 08-01-2020   #7
BigJohn
BigJohn's Avatar
K&N filter when you tear open the cellophane wrapper; put it on a clean paper towel and check it in the morning and you will have your answer.
Old 08-03-2020   #8
Yep, Marc does use the stock AC filter. Says dyno tests of others revealed no material advantage. And I also used to remove the filter completely for drag racing or half mile runs. --Bob
