Old 06-25-2020   #1
Perry Mitchell
Default Extreme rich condition
Before any work was done and before the plenum was removed, the motor ran extremely rich. After talking with Marc and Jerry, I removed the plenum and eliminated the complete secondary system. I replaced all the injectors with FIC ones and the fuel pressure regulator with Jerry's new and improved unit (which I have to say is a work of art). The prom was re-calibrated by Marc and a resistor was installed between pins B22 and C18 on the computer which got rid of the code 66 that I had. I now have NO codes but still have the extreme rich condition. I suspect a failed sensor or vacuum leak but with all the vacuum stuff removed and ports capped off, I am at a loss. Any ideas?
Perry Mitchell is offline   Reply With Quote
Old 06-25-2020   #2
Default Re: Extreme rich condition
How are you detecting the rich condition? Are you using a scan tool? if so, do you have logs?
Old 06-25-2020   #3
https://www.zr1.net/forum/showthread...ght=OBD1+codes
What's a code 66?
Old 06-25-2020   #4
Perry Mitchell
A code 66 is a power fault for the valet switch.
Old 06-25-2020   #5
Perry Mitchell
I do not have a scan tool but what I did was jump the terminals A and B in the ALDL connector and it showed no fault codes, only the code 12. All the plugs are black and sooty and the exhaust is very black and rich. I can't let it run very long as it smokes us out of the area.
Old 06-25-2020   #6
Have u checked coolant temp sensor, not the gauge sensor?
Dynomite,
Need to add Code 66 to ur list of MALF in stickies.
Old 06-25-2020   #7
Perry Mitchell
No, have not checked the coolant sensor. Can I do that without removing the plenum? It is rich right at startup.
Old 06-25-2020   #8
PhillipsLT5
PhillipsLT5's Avatar
Were the FIC injectors new or rebuilt?
Old 06-25-2020   #9
Perry Mitchell
I assume they were new as I bought them from Jerry and I am sure he would have told me otherwise.
Old 06-25-2020   #10
Also, have u looked at Fuel Pressure Regulator. Can u put an FP gauge on the right hand fuel rail?
