06-14-2020 | #1 |
RH oem harness routing
This is a long shot, but does anybody have a good photo(s) of the factory lower wiring harness routing. Ideally on an original car or close to it. Doing a resto and struggling to route the crank position, oil level sensor and passenger O2 wiring.
It?s a 93, so the cats are removed. Which gives me some access. I just don?t have any original photos. Thanks. Sent from my iPhone using ZR-1 Net Registry
Todd ____________________________________ *** our email address has changed! info@pepmeierengines.com pepmeierengines.com Friend us on Facebook too: www.facebook.com/profile.php?id=100011443683384 Pepmeier Engine Development |
06-14-2020 | #2 |
Re: RH oem harness routing
The harness run down behind the right cylinder head. The O2 wiring splits off as seen here
IMG_0847.JPG IMG_0846.JPG The remaining harness runs forward connecting to the oil level and crank sensors. IMG_0842.JPG IMG_0843.JPG Sent from my iPhone using ZR-1 Net Registry
06-14-2020 | #3 |
That gentlemen is a better than new engine and clean engine bay!
06-14-2020 | #4 |
Yes, that's what I was thinking. You want to come and spend the summer with me Phil? Shop is air conditioned & plenty for you to do if you were so inclined.
06-15-2020 | #5 |
Seriously Phil. Does that motor even have any fluids in it? 🤣🤣😉
06-15-2020 | #6 |
Phil for the win. Thanks, man.
06-15-2020 | #7 |
Full credit due to Jerry's excellent gaskets and sealants.
