Old 04-17-2007   #1
Chris H
Default another problem with lighter
I have a 1991 ZR1 the cig lighter doesnt work and the brake lights do (this makes me think its not the fuse) let me know if you have any ideas
thanks
chris
Chris H is offline   Reply With Quote
Old 04-17-2007   #2
Jeffvette
Default Re: another problem with lighter
You have a ohm meter?
Old 04-17-2007   #3
Chris H
is that a volt meter cause if it is yes i have one and there is no read out to it when i check it
Old 10-26-2007   #4
SDZR-1
mine also quit....and the fuse is good...also a 91
SDZR-1 is offline   Reply With Quote
Old 10-26-2007   #5
Pull the console shift plate top. its possible the wire behind the socket is loose. Also mine tends to rotate the housing with causes intermittent contact. Try turning the lighter socket a quarter of a turn to the right or left. May fix the problem
Old 05-04-2008   #6
Chris H
i took the cup holder part of the console up and the cig lighter was unplugged from the back i plugged it in and it works great thanks for the replys
Old 10-14-2008   #7
Chris_32212
i had a cig lighter socket in a used car i bought that wasn't working and it was because of excessive scum and corrosion in the socket preventing good contact points to complete the electrical circuit. this happends alot with cig lighter sockets that get used alot by smokers. so if the socket looks corroded, a good cleaning of the socket could fix the problem. i know you already fixed your issue but i thought i would add this in for anyone else having this issue later.
Chris
