Old 05-17-2020   #1
Corvette95
Corvette95's Avatar
Default Help with throttle body reassembly...
Putting my throttle body back together, the main shaft return springs seems to be weak so I wrapped the spring one more time, it was very tight, then the one of the pieces of wire on the springs wouldn't let the main shaft seat all the way, I took a small "j" hook and remove the spring from the catch, it seems to be better now on to the butterflies, there is no DAG on them nor was there before I took them out. The butterflies do go in and seat at an angle correct?
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 05-17-2020   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Help with throttle body reassembly...
Yes, they seat at an angle.
Let them seat closed first with screws slightly loose. Then tighten screws with the butterflies fully seated.
Don’t forget the red Loctite on the screws.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-17-2020   #3
Corvette95
Corvette95's Avatar
Default Re: putting throttle body back together and return spring seems weak and doesn't snap
Thanks! I am going to need one new brass screw, one of them is damaged where I ground it off. (the secondary butterfly is fine....thanks!)
