Old 05-16-2020   #1
mmkkpro
mmkkpro's Avatar
Default ECM connector colors
Good morning guys, I am trying to track down a miss in my engine. I want to test each fuel injector with plenum off. Mark H has a procedure where he says to unhook the Grey harness to the ECM and ground a number of pins to energize each injector. I don't have a gray connector. I have a yellow, red, green and brownish one. Did they change colors during production? Any help would be appreciated. Thanks.
mmkkpro is offline   Reply With Quote
Old 05-16-2020   #2
mmkkpro
mmkkpro's Avatar
Default Re: ECM connector colors
I took off all 4 connectors and this yellow one matches the gray one MH has posted in his trouble shooting article. The cut outs for fitment to the ECM are the same but the color is throwing me off. I don't want to burn anything up. When I was doing my fuel injectors seems like I read somewhere where during production the colors did change, but can't find that info now.
Old 05-16-2020   #3
mmkkpro
mmkkpro's Avatar
When all else fails, look in the FSM, Page 6E3-A-12, I'm sorry for being a dummy.
Old 05-16-2020   #4
tccrab
tccrab's Avatar
Small piece of advice, while back probing the sockets, be very careful not to stick the DVM probe forcefully down into the sockets. It will stretch out the socket and cause the male pin not to seat properly causing a bad contact which will cause misfiring.
Ask me how I learned this lesson........
'Crabs
Old 05-16-2020   #5
mmkkpro
mmkkpro's Avatar
Thanks Crabs, MH mentions that also in his article. I just got her back together, sounds better, going to test drive and see what happens. Thanks
