Old 05-11-2020   #1
billschroeder5842
billschroeder5842's Avatar
Default Odd Squeak (seemingly) temperature sensitive...?
My OCD is always finely tuned and ready at a moments notice.
My latest obsession is that I notice a squeak coming from the passenger side dash area of my 91 at lower speeds, over roads that have a more "wash board" feel. The funny thing is that the noise happens when the car is "colder" especially when first started and the air from the vents is cool.
When the engine heats and I can push 75 degree air through the system, the squeak seems to go away quickly. BTW, the squeak is a high pitched, "back and forth" three times quick and sounds more plastic in nature. Once the car is warm (or on hot days) the squeak is not noticable.
Anyone ever heard of such a thing? Is there some HVAC components that I need to check? Vents, blend doors, electrical wires? Of course I'm planning a disassemble of the dash passenger side as COVID means I have extra time to be crazy.
Thanks!
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
[SIGPIC][/SIGPIC]
Old 05-11-2020   #2
32valvesftw
Default Re: Odd Squeak (seemingly) temperature sensitive...?
I hate squeaks like that! I assume you took everything out of the glove box and center console? Try driving with glove box door open? Change position of the passenger seat?
It sounds to me like a loose screw, somewhere. Last noise I had like that was a loose screw for the top, I think the front passenger one.
Old 05-11-2020   #3
Check the hood Bump stop.. That was the same/similar noise on mine.. not always, but sounded like rubbing plastic in the dash. my son suggested to check the hood stop.. that was it
Old 05-11-2020   #4
32valvZ
32valvZ's Avatar
Turn the radio up.... it will go away!
Old 05-11-2020   #5
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Or, simply press your right foot down more.
Problem solved!
Marty
Old 05-11-2020   #6
Corvette95
Corvette95's Avatar
Look at the 96 ( I know, not 96 ZR-1) FSM on squeeks and rattles fixes are the most up to date for the time for a C4.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 05-11-2020   #7
billschroeder5842
Thanks this is what I'll do however the radio and gas pedal mash seem way more fun.
Bill Schroeder
Texas Proud!
[SIGPIC][/SIGPIC]
Old 05-11-2020   #8
billschroeder5842
Question.... What kind of access does removing the IP/compartment (glove compartment) give you? I've never had my out so I'm curious if I'm able to inspect ducts, wires and other components.
I'm trying to avoid pulling the whole dash (potentially) apart if I can get through the top IP compartment and/or remove the lower kick panel as I did the dreaded EDM removal a few years ago.
Bill Schroeder
Texas Proud!
[SIGPIC][/SIGPIC]
Old 05-12-2020   #9
DRM500RUBYZR-1
Excellent suggestion!
Marty
Old 05-13-2020   #10
Yep funny I was going to suggest this !
