04-30-2020 | #1 |
Parts Washer Degreaser
I’m looking for feedback on which parts washer degreaser you’ve had positive results with when rebuilding a LT5.
04-30-2020 | #2 |
Re: Parts Washer Degreaser
Crown PSC 1000 Parts Cleaner from local Tractor Supply store.
https://www.tractorsupply.com/tsc/pr...l?cm_vc=-10005 Sent from my iPhone using ZR-1 Net Registry
05-01-2020 | #3 | |
I also use the stuff from Tractor Supply. Cleans pretty good. I usually spray it down with a good brake clean after to get any residue off.
1994 ZR-1 #198, sold [img]https://live.staticflickr.com/65535/48400173802_2a6f122cfb_n.jpg[/IMG] [COLOR=RoyalBlue]96 GrandSport#857[/COLOR],[COLOR=Red]Red Gut[/COLOR] 397 LT4, AFR heads,3:90 gears, DRM longtubes, Sepanek 700R4, Yank 3600, bla-bla... Best ET w/396 & 6-speed 11.02 @126.57 w/1.60 60' Best ET w/396 & 700r4 10.82 @124.87 w/1.48 60' 2003 DarkShadowGray Ford Lightning 460rwhp/550rwtq 12.11 @112.18 w/1.71 60' |
05-01-2020 | #4 |
I appreciate the recommendation. I picked some up at TSC.
05-02-2020 | #5 |
Everything today is aqueous based.
After cleaning, you have to rinse each item, then dry it to keep it from rusting. In the good old days we used Kerosene or #2 Diesel. Not so good for your skin or your lungs and is hazardous in oh so many ways. But it works so well........ 'Crabs
05-02-2020 | #6 |
Sometimes I use the dishwasher when she’s not home.
Use oven for fast drying paint on metal parts too - works real well. Sheee! |
