![]() Join Date: Jan 2006
I have read the threads on injector o'rings, I am replacing the IH O'rings, I have ohm'd these injectors all are good. This is how they came out, is the o'ring set up correctly and properly identified.
One thin guy to look for is the spray pattern . My checked out ok till I took off plenum and turned on fuel pump and 2 just sprayed a stream
But do the rings look right for the primary and secondary ?
Set up looks the same, the primary should be on left of your photo with orange tip the on on the right is secondary...right?
![]() ![]() Join Date: Aug 2005
Free: Thanks, Jerry! Jerry's Gaskets
https://www.jerrysgaskets.com/lower-...llation-guide/ http://www.zr1specialist.com/HAT%20W...eplacement.pdf
1995 ZR-1 #106 Blk/ Blk Owned by me since 2000. 93K miles, but not on motor :-) Mods the way I want it, Not afraid to drive it! Last edited by tf95ZR1; 04-23-2020 at 11:43 PM. Reason: Wanted 2 |
![]() Join Date: Nov 2007
For what it's worth here (maybe) the Accel injectors (part # 150821 @ Summit Racing) which many, many ZR-1s are running on are identical, i,e., they both have provision for an O-ring at the injector tip. However, on the 1990 ZR-1 ONLY, the ridges provided to hold the O-ring on the tip of the primary injector can be ground off @ your discretion. (Theoretically, the ridges left on provide a bit of turbulence in lieu of the injector boss [often removed as part of the full porting of the 1990 IHs] to promote better atomization of the fuel.)
![]() Last edited by Paul Workman; 04-24-2020 at 07:34 AM. |
