![]() Join Date: Mar 2008
I looked in the FSM and can not find where the clutch start relay is located. Does anybody have a picture of the location of the clutch start relay? I have a 93 ZR-1.
Roy
Roy L. Carman If I feel the need for speed, I just think about flying the B-777. ![]() 1989 Dk Blue Coupe lost in divorce 1991 Black Coupe SOLD 1992 Black ZR-1 #423 SOLD! 1993 Ruby Red 40th Anniversary ZR-1 #334 1995 Black ZR-1 taken by ex-wife 2002 Pewter Coupe no idea where it is 2003 50th Anniversary Corvette #No idea what number SOLD! ZR-1 Net Registry #516 Grand Sport Lifetime Member NCM Lifetime #1468 |
![]() Join Date: Apr 2004
Safety switch?
Remove the hush panel under the steering column, remove your drivers seat. lay on your back with your head against the clutch peddle and you'll see it...LOL yes its a pain in the A$$..
Steve 1990 Steel Blue/Black #2355 1990 Red/Red #1473 1991 Quasar /Black #118 Sold 1991 Turquoise/Black #766 Parted Out 1993 Yellow/White #179 Sold 1990 Black/Gray #1361 Headers/4:10s Sold Last edited by We Gone; 04-12-2020 at 07:50 PM. |
#3 | |
I know where the clutch safety switch is. It's the clutch relay switch that I was looking for. I think that it is in the engine compartment. I have a 93 ZR-1. It's different than the earlier models. Roy
![]() Join Date: May 2007
The starter relay is located under the driver's hush panel. It's under the aluminum crash support panel. The starter relay socket has two yellow wires, a yellow/black wire and the purple wire that goes to the starter. To bypass the relay insert a jumper between relay socket pins 30 and 87.
#5 | |
Marc, thank you for the help. However, I do have one question. Paul Workman referred to it as clutch start relay. One of the FSM's refer to a start enable relay and the other FSM refers to as a start interrupt relay. I'm taking a shot in the dark but I'm thinking that we are all talking about the same relay since it has the wire color coding that you have refer to. Thank you for the assistance. Roy
Hi Roy,
Yes, all of those descriptions apply to what I call the starter relay. You know you have the correct relay when you see the 5mm/10 gage purple wire connected to it. Note that on a '93 and up cars, if the starter relay is bypassed the engine will crank without pushing down the clutch pedal. Even if the clutch switch is still connected. The clutch switch controls the relay, not the starter on the '93 - '95 cars. I think that it's good for the crankshaft thrust bearing to not have the pedal depressed when starting. That way there is no load on it before oil pressure builds. Last edited by Marc Haibeck; 04-16-2020 at 02:56 AM. |
Thanks for that information. On my 92 Z, it wouldn't start until I bypass the clutch safety switch. Never had a problem since then. I do the same thing to my 93Z, I still had a problem starting. The relay could be going bad so that is why I asked. Thanks for the help. Now if I could just get my 92 up there for some TLC.
Roy
Just bypassed my Clutch Safety Switch on 90' #3032 and 91'
![]() I made extra Bypasses (each about 3" long) for my other 90's. I left the original Clutch Safety Switch in place. ![]() ![]() The Electrical Bypass (3" pre-soldered connector) can be installed in 10 min by removing the front two, side two, and bottom three Hush Panel screws (7mm hex head) as well as the nut from bolt holding Hush Panel up on the Fire Wall (Drivers Side). The Hush Panel Light has to be unplugged once the Hush Panel is loose. The Clutch Safety Switch Connector is easily identified with the two larger gauge wires (yellow and purple). The yellow wire controlled by the key switch and the purple wire to the Starter Solenoid (or in my case the added Starter Relay installed under the ECM). The Clutch Safety Switch connector can be easily separated with one locking tab release. The end of the connector with the yellow and purple wires has two electrical tabs included as shown. The other end of the connector going to the Clutch Safety Switch can be tucked away under the steering wheel. ![]() ![]() The 3 inch 12 gauge yellow connector Bypass can be connected to the existing tabs within the connector without any electrical tape required since the connectors are very well insulated within the connector and very tight. The Connector with the Bypass can then be tucked upward above the Hush Panel and the Hush Panel placed back into position and secured by the seven screws (7mm hex heads) and the Fire Wall nut and washer. ![]() You now have a Start condition without the requirement to depress the Clutch as long as Transmission is in Neutral. You can depress the Clutch to make sure you do not lurch forward just in case the transmission was left in a gear. You also now have eliminated one of the NO START issues associated with the Clutch Safety Switch. The original Clutch Safety Switch is left as installed with no issues. Post 293 - Bypassing Clutch Safety Switch
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-16-2020 at 01:06 AM. |
#9 |
Roy glad you found what you were looking for....
#10 |
![]() Join Date: Nov 2007
This is the graphic I contributed to an presentation by Marc (IIRC).
Anywayz... Old info for most of us, but for the benefit of the new Z owners, this may clear up some questions? The 90-92 Zs routed the starter solenoid current through the clutch safety switch that was activated with the clutch pedal, whereas the 93-95 Zs utilized that switch to activate a relay to handle the relatively high current that clutch safety switch had to handle. That clutch safety switch (located on the clutch pedal arm) is difficult to get to, requiring one to remove the seat so one can lie on his/her back and access/service the switch. However, due to the current load, it is only a mater of time before that switch will fail again. The solution was to hand off the start solenoid current load to a relay and simply use the clutch safety switch to activate that relay - which was a factory modification present on the 93-95 ZR-1s. Two solutions for the 90-92 model years: 1) Install a starter relay*: Cliff (aka Dynamite) and I colluded to develop a modification for the 90-92 MY Zs by installing a relay and routing the clutch safety switch to control that relay, similar to the 93-95 solution. (See SOLUTIONS sticky for details.) *NOTE: This relay mod applies only to the 90-92 MY Zs as the later 93-95 models already have such a relay mod installed as a factory-designed modification. Thus, this makes an additional relay (in series) redundant and unnecessary. 2) Bypass the clutch safety switch (with a jumper or solder join the leads together). This modification eliminates the (nanny) safety switch resulting in the starter being activated with the ignition switch alone. One must either press the clutch when starting the engine unless the transmission is in neutral. Otherwise, the car will lurch when the starter engages creating a potential hazard; a hazard increased if the engine starts as well! |
