Old 04-11-2020   #1
Bradjon
Default Fuel injectors
It’s time to get new injectors for my 90 which ones do you guys like the accelerator or the tic injectors and if it’s the accele what is the part. Umbers please thank you so much
Bradjon is offline   Reply With Quote
Old 04-11-2020   #2
Bradjon
Default Re: Fuel injectors
Oops sorry new phone accells or the fic injectors
Old 04-11-2020   #3
Either works fine particularly in a stock motor.
Old 04-11-2020   #4
The Accel injectors are the 150821s from Summit Racing.
NOTE: There is a plastic nub for connector indexing which has to be ground off of injectors to be inserted in the secondary ports. No biggie. It takes about 5 seconds with a Dremel to zip the nub off. That's it.
That said, Jerry's Gaskets can provide FIC injectors AND the proper Vinton O-ring seals - as a complete kit. Just let him know it is a 1990 to be sure you get the correct O-rings.
Swapping injectors is a DIY project. Easy Peasy! And, I'm using the Accel injectors - installed over 10 years ago now. Still running perfectly!
Old 04-12-2020   #5
TX '90 ZR1
TX '90 ZR1's Avatar
I would recommend contacting Jerry. Just let him know what you are doing and he will know the correct parts you will need.
Jerry is a Godsend for maintaining the LT5. He supports us. We should support him.
(My 2 cents worth, but I believe worth more!)
Kenny
1990 #442
Old 04-12-2020   #6
You're right Kenny--I think Jerry owes you a commission! But you are also very right that Jerry is the guy to go to for parts and knowledge and deserves all the recommendations he gets. --Bob
Old 04-12-2020   #7
Vette Guy
Vette Guy's Avatar
As Marc recommended Accel injectors for a stock replacement, I’ve used them and have been happy. See his article regarding injectors below. My 91 runs them, and it makes somewhere around 450hp using the stock size.
http://zr1specialist.com/HAT%20Web/a...eplacement.pdf
Even better, I was able to purchase the Accels for about $500 for all 16 via Amazon. If you do not need them right away, you can monitor Amazon’s price fluctuations via the below link.
https://camelcamelcamel.com/ACCEL-15...uct/B0006HJO3G
Mark Horner
President, ZR-1 Net Registry
91 ZR-1 #2016
95 ZR-1 #21 DRM-600, LPE 385
Vette Guy is offline   Reply With Quote
Old 04-12-2020   #8
Bradjon
Thanx so much for the amazon idea living on ssi I need to sabe every penny I can
Old 04-12-2020   #9
Driller1
Driller1's Avatar
just a few weeks ago bought the full set of 16 FIC injectors from Jerry
with plenum gaskets etc.
I couldn’t be happier. Unbelievable how smooth and responsive the car is.
He’s got everything in stock.
FYI buy several of the little gaskets for injector electric plugs.
You’re SOL if you drop one and don’t have any spares.
If you have not removed plenum before Marc Haibeck has a DVD he’s sells
that makes job very straightforward after watching it.
1967 Corvette 427/L36 Goodwood Green Convertible NCRS Top Flight
1969 Z/28 DZ302 Fathom Green
1971 Corvette 454/LS5 Brands Hatch Green Coupe NCRS Top Flight
1980 Z/28 Coupe 383 Stroker 450hp Black/Black
1987 Corvette Z51 4+3 Coupe Bright Blue (SOLD)
1991 Corvette ZR-1 LT5 Bright Red/Red #141
1997 Viper GTS Hennessey Venom 700hp GTS Blue
2006 Ferrari F430 Gated 6M Rosso Corsa/Nero(SOLD)
2007 Corvette Z06 Victory Red
2009 Corvette ZR1 Cyber Gray 3ZR #1037
2011 Ferrari 458 Italia Grigio Silverstone/ Nero
2015 Corvette Coupe Z06/Z07/3LZ 7speed Torch Red/Jet Black
2015 Camaro Z/28 LS7 #854 Black/Black
2019 Corvette ZR1 Sebring Orange ZR1/ZLZ/ZTK/3ZR 7 speed #289
Driller1 is offline   Reply With Quote
Old 04-12-2020   #10
Had Accels in mine for over 10 years. Motor ran great but several of them finally failed in terms of poor spray pattern w one of them having the aerator disintegrate to the point of causing detonation in my #7 cylinder. Again, I was happy w the Accels but decided to switch to FICs because they are sold as a matched set, ie flow rated within 1% each other. I’m a bit anal about my tune, so I change tune to reflect the Injector Voltage Compensation for different imjectors.
