Old 04-07-2020   #1
Bradjon
Default Weird water leak
Went out to start the car and found fluid on the ground so I backed her out topped her off took about 6 oz started her and no leak got her all the way up to temp and no leak . Put her back into the garage and ant out this morning and fluid on the ground looks like it’s coming from the center of the car . Oh felt the hoses and then popped the radiator cap and it seemed like it had pressure . Any ideas where to look ?
Bradjon is offline   Reply With Quote
Old 04-07-2020   #2
Subfixer
Subfixer's Avatar
Default Re: Weird water leak
Probably just condensation from the Air Conditioner evaporator. It drains around the location of the passenger door, about a foot in from the side of the car.
2021 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black
Old 04-07-2020   #3
Water or coolant?
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 04-07-2020   #4
Bradjon
It’s defiantly.coolant nice and green
Old 04-07-2020   #5
Ccmano
If you have one, hook up a cooling system pressure tester to the system and start tracing the leak. If you don’t have one normally I’d say go to AutoZone and rent one, but I’m not sure they’re open. They’re cheap at Harbor Freight too.
Is the leak center front of engine or center back?
H
Old 04-07-2020   #6
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
look at lower radiator hose carefully.
Marty
Old 04-07-2020   #7
Bradjon
Hans it at the center front of the motor
Old 04-07-2020   #8
Ccmano
Do a pressure test as I described if you have the tool. Sounds like either a hose or the water pump. The pressure test will show it leaking.
H
Old 04-07-2020   #9
Bradjon
Could the water pump cause what’s going on
Old 04-07-2020   #10
Ccmano
Yes, there’s a seal at the front of the pump. You’ll see it leaking out from under pulley. With the pulley off you’ll see a weep hole on the bottom of the pump nose. That’s where it will come out if it’s the pump. If thats the case, I would send the pump to Haibeck and have it resealed and the bearings checked, unless you find a new/old stock AC/Delco pump. The Chinese replacement pumps that are currently sold are sketchy at best.
H
